Is it bad to Max out Injectors
Hey folks, I am trying to understand why everyone throws really large injectors on their cars instead of running lower injectors to their fullest potential. As long as your not leaning out, why would you not want to run something to its fullest potential?
YOU NEVER WANT TO RUN INJECTORS OVER 90% DUTY CYCLE. Injectors will potentially run in unpredictable manners and spray patterns at their limit.
That is all.
Tom
(OK 90% may be uber conservative, maybe 95% but I'm sure the true tuners will chime in with the same or close to the same answer)
That is all.
Tom
You can run 90% IDC but you need to monitor that very closely especially in the NE or any place that has wide range of temp changes. The reason is that if you are already 90% IDC in the Summer then you will be most likely go way above that in the Winter because the ECU will add more fuel to compensate for the colder/denser air. Most tuner will recommend not to go above 85% for the reason I stated, it just give you more more room on colder weather.
But you do reduce the margin for error...
