Joining the FI 500 HP club..
List of Goodies…
Aftermarket parts
Wiseco pistons
Pauter rods
ARP- main studs
ACL bearings set
Fluidamper crank pulley
BC 272 cams *maybe*
BC spring, retainer, keeper set
BC intake valves
BC exhaust valves
Greddy 20g wit/ larger FMIC.
Greddy type Rs BOV
Greddy TT evo 2 exhaust
Greddy univ catch can
18g FMIC is for sale (**complete brand new**)
GTM HD oil cooler
GTM H.O. 14’’ dual fan kit
AMS performance radiator
Pathfinder cooling kit
Silicone coolant hoses
Nismo thermostat
AEM water/meth injection kit
Deatschwerks 600c injectors
Aeromotive FPR and custom Fuel return system
HKS Evc boost controller
Greddy turbo timer
Utec + map sensor
Innovate LM-2
HKS CAMP system
OEM parts..
VQ35 HR head studs
HR head gasket
Engine gasket kit
Revup oil pump
Rear main seal
Camshaft timing chain
Main timing chain
Main chain tensioner
Camshaft chain tensioner
VTC solenoid gaskets
Factory oil filter
Aftermarket parts
Wiseco pistons
Pauter rods
ARP- main studs
ACL bearings set
BC 272 cams *maybe*
BC intake valves
BC exhaust valves
Greddy type Rs BOV
GTM HD oil cooler
Nismo thermostat
Greddy turbo timer
Utec + map sensor
Innovate LM-2
HKS CAMP system
OEM parts..
VQ35 HR head studs
HR head gasket
Engine gasket kit
Revup oil pump
Rear main seal
Main timing chain
Factory oil filter
List of Goodies…
Aftermarket parts
Wiseco pistons
Pauter rods
ARP- main studs
ACL bearings set
BC 272 cams *maybe*
BC intake valves
BC exhaust valves
Greddy type Rs BOV
GTM HD oil cooler
Nismo thermostat
Greddy turbo timer
Utec + map sensor
Innovate LM-2
HKS CAMP system
OEM parts..
VQ35 HR head studs
HR head gasket
Engine gasket kit
Revup oil pump
Rear main seal
Main timing chain
Factory oil filter
Aftermarket parts
Wiseco pistons
Pauter rods
ARP- main studs
ACL bearings set
BC 272 cams *maybe*
BC intake valves
BC exhaust valves
Greddy type Rs BOV
GTM HD oil cooler
Nismo thermostat
Greddy turbo timer
Utec + map sensor
Innovate LM-2
HKS CAMP system
OEM parts..
VQ35 HR head studs
HR head gasket
Engine gasket kit
Revup oil pump
Rear main seal
Main timing chain
Factory oil filter
U might be able to save some by going with eagle rods. Not sure if the HR head studs will be good for that much hp and u may need an walbro fuel pump.
![](https://farm4.static.flickr.com/3453/3361938796_f0c4719539.jpg?v=0)
To me it looks the same as the one that comes with the 18g kit. I was thinkin there was gonna be 4 inlets vs the 3, but it does look a lill beefy then the other one I have.
I do like your taste in choice in bumper. kinda reminds me of my idea's of what I was lookin for. It hides the IC very well hopefully the air ducks provide enough airflow to the IC.
![](https://g35driver.com/forums/members/nyqueenz-albums-my-lr-whip-crew-picture9849-m.jpg)
as far as drivetrain already installed
ACT 6 puck
ACT light flywheel
brandnew 6 speed trany
B&M short shifter
RP fuilds, trans/diff
Stock Brembos
Stoptech 2 piece rotors drilled
BFG braided lines
Hawk pads
Also the HR head studs are rated at a high clamp rate, per Jim wolf he runs 600-800hp cars on the track all day long using these studs and a heck alot cheaper the L19s. It all comes down to tune. Not worry bout the cost on the rods thou i have done a build with pauter they are well worth the cost of the metal
http://www.jimwolftechnology.com/wol...HEAD_BOLTS.pdf
http://www.enginebuildermag.com/Arti...ner_facts.aspx
http://www.a1technologies.com/site3.php?id=271
Don Trapp of A1 Technologies says his company starts out with the basic alloy 4340 or 8740 that is 190-ksi minimum. From that point it goes up to 280 ksi. “The 4340 or 8740 is already far above an OEM fastener in strength and quality. We use a lot of H11, which is a toolsteel for Top Fuel, Funny Car and some in Top Alcohol and Injected Nitro classes use it also. This is a 240 ksi minimum graded material.”
The next step up from 4340 or 8740 steel is 1722 (AMS 6304). Manufacturer ARP calls it ARP 2000 and it’s all the same material, a 220 ksi material. The next step would be H11, which ARP calls L19. It too is the same material and also comes from Carpenter. Those are getting up to 240-250 ksi. You can go higher than that but it becomes brittle, according to Trapp.
#30
