Fuel return sys..
Old Apr 15, 2009 | 03:49 AM
nyqueenz's Avatar
Fuel return sys..
After countless hours and comparing notes. I have decided to build a custom fuel return system utilizing these rails.
and of course...
600 cc
Comments welcome.
Old Apr 15, 2009 | 12:54 PM
GreenGoblin's Avatar
The goblin resurrection
What rails are those?
Old Apr 15, 2009 | 01:22 PM
tiguy99's Avatar
I'm curious also. What kind of FI setup are you going to use these with?
Old Apr 15, 2009 | 01:23 PM
superchargedg's Avatar
Hes going with the greddy twins and i think its the 20g's.
Old Apr 15, 2009 | 01:55 PM
escobar929's Avatar
those rails look deebo
Old Apr 15, 2009 | 06:53 PM
tiguy99's Avatar
I wish I had twins in my garage. I gotta hurry up and grab one of these FI systems soon.
I want to get this done so I can go too
Old Apr 15, 2009 | 08:05 PM
2slo2bfurious's Avatar
Nice choice, I was going to go with that same setup before too http://www.rossmachineracing.com/350zrail.html for those of you who dunno.
Old Apr 16, 2009 | 11:39 AM
Jtrain's Avatar
Deebo? I can't keep up with this SOFLA lingo anymore.
Why do the FL guize dominate the F/I forums??
Old Apr 16, 2009 | 09:56 PM
Iceman8's Avatar
Op..can you give us some info as to why you choose to go this route? Btw those rails look dope.
Old Apr 17, 2009 | 03:10 AM
nyqueenz's Avatar
That’s where I found the rails from too. From what I’m getting a stage one fuel return system utilizing stock rails could support upwards of 500 RWHP so basically (adaptors, clips, FPR and lines). I was originally gonna go with that plan cause I couldn’t justify the high dollar AAM rails even though they bring bling to our engine bays. Basically for half the price these should be more than enough to get the power goals of my needs.
Here is another intresting site I found who makes custom rails..
http://www.injector.com/fuelrails.ph...b3d37133e5492c
Old Apr 17, 2009 | 03:16 AM
nyqueenz's Avatar
The link to the page where I found the rails is on this thread. The reason why I’m going this route is better fuel sustainment, cost efficient, quality and brings bling the engine bay without breaking the bank (gotta break bread with this overall bad economy) oh important point I missed. “I luv custom fabrication”
Old Apr 17, 2009 | 03:20 AM
nyqueenz's Avatar
humm interesting also..
Hydraulic Pulsation Damper
Designed to absorb the hydraulic shocks produced in fuel rails by the opening and closing of injectors. Will help eliminate fuel pressure "bounce" and uneven fuel distribution. Red-anodized, billet aluminum body features a Schrader valve test port for fuel pressure and sample checks. Inlet is 3/8" NPT.
Old Apr 20, 2009 | 04:25 PM
Custom is awesome but forgot to mention that the most important parts are the fuel pump bucket pieces. Its the regulator delete and other fittings. I've tried to make my own stuff, but those leaked. I recommend you look up CJM, you can order those custom machined pieces from them. Kinda expensive for what they are, but could save you some trouble. Or if you have access to a machine shop maybe you can make your own. Those are the only parts you will need that aren't 'off-the-shelf'.
Old Apr 21, 2009 | 04:01 AM
nyqueenz's Avatar
more info please.. "fuel pump bucket pieces"
Old Apr 21, 2009 | 12:42 PM
This one you don't need 100% but it
makes running -AN line a little bit easier.
This is the important part, looks simple, but theres no way to find anything anywhere that would work so its got to be this or custom.
http://www.cj-motorsports.com/catalog350z.htm
