Where to Mount Catch Can
Old Apr 22, 2009 | 09:13 AM
Silver350GT's Avatar
Hey folks, I got the NRG catch can to help with my pressure problem, but I can't find anywhere to mount that thing. I have seen a couple of members mount them on their sides ontop of the radiator fan shield. Is it OK to mount on its side/back? The drivers side of the engine bay is filled by the Vortech, and the passanger side has a spot, but I would need to get a replacement for the current Overflow tank.
So what do you guys do?
Old Apr 22, 2009 | 12:10 PM
waijai's Avatar
i.love.gold
I replaced my PS tank and have the oil catch can right next to it on the passenger side of the motor. Removed my hood sensor bracket too.
Old Apr 22, 2009 | 03:07 PM
D-tuned's Avatar
I have my oil catch can mounted to the top of the radiator fan shroud. this weekend I'm going to mount it on top of the intercooler behind the grill.
Old Apr 22, 2009 | 04:03 PM
Are you putting it Horizontal or Vertical? I had it sitting there this weekend, looking at that as an option, but I figured it wouldn't be easy to get the lines up there, and I figured the longer the lines, the less effective it would be. But maybe not...
Old Apr 22, 2009 | 04:49 PM
D-tuned's Avatar
I plan on mounting it horizontally. I have one port from the catch can going to turbo intake tube. I'll be making a bracket so the catch can sits right above the intercooler.
Old Apr 22, 2009 | 06:37 PM
superchargedg's Avatar
I mounted mine the same place on the drivers side rad shroud.
Old Apr 22, 2009 | 06:40 PM
ttrank's Avatar
Grocery getter
Mine is mounted on top of my radiator. I don't have the fan shroud because I have a 50mm radiator. I have the WR one, cut it in half and divided it into two, now half is a crank case vent and half is a catch can.
Old Apr 23, 2009 | 09:09 AM
Cool Cool..thanks for the info guys.
Old Apr 23, 2009 | 04:04 PM
alan21's Avatar
heres mine
Old Apr 24, 2009 | 10:26 PM
rcdash's Avatar
Mike Norris Motorsports sells a catch can that is very well designed. It attaches with a single bolt to the front of the timing cover area.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
Claudiu
Sep 26, 2015 01:04 PM
beto4632
Sep 23, 2015 04:28 PM
