Friend having issuse wit his TN kit....
Old Jun 15, 2009 | 01:27 AM
nyqueenz's Avatar
Basically my boi runing a TN kit on stock block.. put down 369 wrhp, now upgraded with Cosworth, fuel return, new injectors, UpRev, etc. and I believe a UTEC for the EMS now he put down 317 rwhp? They say hes running lean.. what do you guys thing is going with this issue?
https://g35driver.com/forums/nationa...vey-aam-2.html
Originally Posted by MaxGsII
FT tuned it for me, and after all the work I had done, only got 317 whp. I dropped it off to FT puttin down 369 whp (on JE's dyno) before the Cosworth, fuel return, new injectors, UpRev, etc. I just want my **** to run smooth with max HP.
Trust me...it wasn't a trap. I witnessed the dyno, with prob 25 other Folks. Mike (AAM) told his Dad that he wasn't going to do the 3rd pull; could have blown my engine!!! In fact, Mike said had it been wintertime, I WOULD have "likely" blown my engine. It was about 80 degrees, but my body temp was hovering around 5,000,000!!!! I await AAM diagnosis. If need be, I'll tow that SOMBEECH to JE, in a heart beat!!!!
WTF, YO?!?!?!?!
Old Jun 15, 2009 | 08:23 AM
escobar929's Avatar
maybe they f---ed the install on the fuel return and its not getting enough fuel, the utec could be bad or its a crappy tune
Old Jun 15, 2009 | 08:29 AM
terps's Avatar
from my understanding he HAD a utec and then switch to just a uprev retune. Car sounded like doo doo, maybe it was slipping the clutch and just hoovering around 5k or something. Maybe the ecu was pulling alot of timing/cutting fuel. apparently it was knocking like a jahova's witness
Old Jun 15, 2009 | 08:34 AM
Glex25's Avatar
Administrator
Did he tune the Utec after putting in the new parts.
His old tune would be worth squat if he didn't tune for his new mods.
Old Jun 15, 2009 | 08:53 AM
terps's Avatar
was retuned after mods, lost 50ish hp(different dyno also)
my vote for repair would be pfsupercars for retune(block away from AAM), hills garage for mechanical repairs. and ive had extensive work done at AAM and Function.
Old Jun 15, 2009 | 09:10 AM
Clint@Altered's Avatar
We'll figure it out.
Upon first look, Needs a tune adjustment, possibly something funky with the upgraded MAF going on as well.
So far pulled the plugs, Plugs shot, gapped incorrectly.
Old Jun 15, 2009 | 09:17 AM
terps's Avatar
they the iridiums? those shoudnt even be gapped. i know dave usually uses those. one of mine was gapped incorrectly also from orginal install
Old Jun 15, 2009 | 09:26 AM
Gap is not that bad, just not what I would recommend. Plugs are simply shot from running WAY too lean.
Old Jun 15, 2009 | 09:41 AM
Glex25's Avatar
Administrator
What was it gapped to?
I usually gap my plugs to around 35
Old Jun 15, 2009 | 10:08 AM
nyqueenz's Avatar
the car is auto i belive..
Old Jun 15, 2009 | 10:32 AM
terps's Avatar
its an auto
iriduims come pre gapped to .44
he's in good hands clint will get it figured out. imo its def. a tuning issues or fuel delivery issue(mechanical failure). with rfs and powerlevels he is more than adequately covered.
I'm not a fan of the uprev flash for fi at all, or really any setup. maybe he's fried his ecu. I hear with flashes they can go bad. when I fried my ecu and utec I ran into similar issues.
honestly I would throw the utec back in there and get a retune. unfortonatly tune, inspection, plug change and other jazz will be upwards of 1k before your out the door. but hell his cosworth plenum was more and atleast he will gain power from the fix.
Old Jun 15, 2009 | 11:57 AM
^ Thanks.
Plugs were copper NGK3672, gapped to about 38 or so.
Pulling the plugs was just the first thing we did. I don't want it to be driven - and from the look of the plugs I'm glad we didn't.
Fresh set of LFR6A-11s are in and we'll finish looking over the rest of the vehicle later before we move on to looking at the maf/tune.
BTW, its a beautiful car. I'm looking forward to getting it up and running correctly.
I'll update when I have some info.
Old Jun 15, 2009 | 12:57 PM
cc1012's Avatar
pics when you get a chance?
Old Jun 15, 2009 | 01:31 PM
nyqueenz's Avatar
so whats the deal i keep hearin even with the UTEC you have to flash your EMU? some please fill me in?
Old Jun 15, 2009 | 01:48 PM
terps's Avatar
from my understanding he HAD a utec(put down 360sih), then when uprev came out with "the new hotness" the utec was ditched and rfs,cosworth, other supporting mods were installed and reflash was tuned. that is what a few customers from that tuner have done
