NEED HELP with SUPERCHARGING MY G35
Old Jun 18, 2009 | 10:30 PM
shafferjohn92's Avatar
i have a 2004 G35 coupe. i want to supercharge it but do not know if the tranny will hold? i need to know what i should buy so the supercharger will be safe and ok for my car. i was told i need to get headers, intake, exsaust and that would be enough? help please, thanks
Old Jun 18, 2009 | 11:07 PM
Need4SPEED05's Avatar
I don't know if you actually need intake, headers, and exhaust to supercharge your car. Those items may just bring a smidge more horsepower to your car. If you just want decent power (330-360whp), just supercharge the stock motor and leave everything else the same. You will have a nice bump in power and be relatively safe with a decent tune (you will probably need a piggyback or Engine Management System for safe boost).
As for the tranny are you MT or AT? If AT, you will probably need to get some stronger internals (levelten.com). If MT, then you're tranny should hold up okay. May just need a better clutch and flywheel. Overall, the tranny will exhibit more stress than normal which is always a risk. Good Luck.
Old Jun 18, 2009 | 11:54 PM
Chef-j's Avatar
http://my350z.com/forum/forced-induc...questions.html
http://my350z.com/forum/forced-induc...for-noobs.html
Read this two threads, it will help you a lot. Good luck.
Old Jun 19, 2009 | 12:15 AM
boost
how much boost? i heard only 6-8 to keep my car safe and ok. and if anyone has links to certain parts for the internals, that are best for the car. can you send them this way.
Old Jun 19, 2009 | 09:55 AM
Chef-j's Avatar
I will say 10~12 is ok, long as you have a right setup and right tune
Old Jun 19, 2009 | 01:07 PM
set up
what would be the right set up?
Old Jun 19, 2009 | 03:53 PM
Chef-j's Avatar
Power is going to be there, even later will easy to pull more.
I would save more for ems and rfs, Standalone is expensive, but it will save you in future. Also rfs, atleast get a stage 0, that also help you in many headche.
Some says it not needed if you not looking for big power, BUT you will always want go more.
That's just my two cents
Old Jun 19, 2009 | 06:34 PM
superchargedg's Avatar
If you are a 5at stay away from levelten as they are a bunch of idiots when it comes to our trans.You need to talk to GTM or ForgedPerformance.
Old Jun 21, 2009 | 01:34 PM
Dv8's Avatar
Dv8
If you search my threads, youll get a lot of answers.
~Dv8
Old Oct 13, 2010 | 11:05 AM
Jiggy813's Avatar
Anyone have any reviews or opinions on the SFR twin turbo kit for the 06 g35 coupe. I was considering getting it since i see it can be used in the AT models
Old Oct 13, 2010 | 11:12 AM
LordFappington's Avatar
Nice bump for an old thread. Cant say I ever heard of SFR much.
Old Oct 13, 2010 | 11:14 AM
Jiggy813's Avatar
Here is the link with the kit http://www.turbokits.com/g35_turbo_kits.html and btw its the TT version
Old Oct 13, 2010 | 11:21 AM
It looks pretty promising, depends on the power you are looking for. I like t3/t4 hybrid turbos because it has the good characteristics of both types. I say I would rather have a supercharger instead of any turbo setup for an AT car.
Old Oct 13, 2010 | 11:24 AM
Jiggy813's Avatar
ya people say both on terms of SC or TT but i saw a couple things about the SC that turned me to TT, but i guess its all opinions. I just want to make sure to others that the kit looks (spec wise) worthy to buy.
Old Oct 13, 2010 | 11:26 AM
Well its a bit pricey for a kit thats using turbonetics.
