I blew up my VQ35DE with the turbonetic at 8psi
Old Jul 30, 2009 | 12:47 PM
YanniXr's Avatar
Originally Posted by GreenGoblin
Where are you from, we can direct you to the best place to get fixed up.
im from ottawa...
yeah if you could tell me where to go!! will be great..
i need to know all issues... i ready that turbonetic is a piece of **** on my350z.com everybody says go POWERLAB... too late for me.... so i have to deal with that...
so as far as i read in every forums on internet...
people says :
utec
get it tune
fuel injector..
but also water cooled something....
and wastegate that opens dump...
this is the result of my research.. dont really understand the meaning.. but thats what i will tell my mechano to check for lol
anymore advice ??
is there any PRO around my place ? MONTREAL TORONTO ??? someone who actually already done it...
Old Jul 30, 2009 | 01:07 PM
Chef-j's Avatar
Canada?
You know them? http://my350z.com/forum/na-builds/44...enum-test.html
Old Jul 30, 2009 | 01:56 PM
YanniXr's Avatar
Originally Posted by Chef-j
i dont see any shop name in that thread ??
Old Jul 30, 2009 | 01:58 PM
twin001's Avatar
Originally Posted by Sylvan Lake V35
My guess would be the ECU reflash was off on its tune and thats why you blew your engine. At the very least you should run an air fuel gauge in order to tell if your running rich or lean or at the absolute minimum go to a tuner with a wide band and have check and make sure your AFRs are where they should be.
Exactly.....but tools are useless unless you know how to use them. It doesn't appear that the OP knows much about EGT's or A/F ratios. He could be running 14:1 on 6 lbs and not know just how dangerous that is. Before diving into such a project with limited support he should research the topic heavily, unless he just wants to burn through his savings.
Old Jul 30, 2009 | 02:14 PM
YanniXr's Avatar
yeah my friend... it already cost me 10 000$CAN for turbo + install... 2 gauges, turbo timer and a set of tire... now i need a motor lol and re-install everything... plus probably a utec...fuel injector., fuel management thing, ... and get it tune.. it hurts... ! need to find a good shop around ottawa for that as soon as possible.. toronto montreal.. not so far for me... anyway !! help
Old Jul 30, 2009 | 02:18 PM
sliderg35's Avatar
$10,000 - that's half of what it cost me but I have not had issues that I couldn't fix myself. The proper tune is the key to keeping your engine alive - any other problem can be addressed fairly easily (with more $$).
Old Jul 30, 2009 | 02:26 PM
YanniXr's Avatar
ya but i blew it up because the shop i went to see was supposed to know what they were doing...they should have get it tuned...
Old Jul 30, 2009 | 03:09 PM
Chef-j's Avatar
I really hate you tell you but you must not really love to looking for something. Just simply click his user name and you can see his homepage.
http://www.sg-motorsport.com/
CHudson Coupe's Avatar
I'll shoot you another pm, but there is no need to bash Turbonetics. Yes, other kits may be superior as far as power capability and responsiveness, but the basics are all the same. A turbo spins and forces air into the engine, in this case, an engine that was never meant to be boosted. So people that say Turbonetics is crap either installed it incorrectly, or did not do enough research and purchased a perfectly good kit that simply did not meet their power goals.
A turbo kit is a turbo kit, now if Turbonetics kits had turbines flying through the intake into the motor and blowing it up it'd be a different story. And they solved boost creep problems early on, so the kit is fine.
If I were you I'd pick up a used engine and have it installed, and get it tunes. Or you can sell the car to me for cheap and I'll fix it myself haha. Turbonetics G35 is a killer DD. My FD is not nice for going around town.
Old Jul 30, 2009 | 03:18 PM
YanniXr's Avatar
ottawa
i could go as far as montreal or toronto if you find a shop for me
Old Jul 30, 2009 | 03:22 PM
djamps's Avatar
Stock MAF maxes out at <6psi @4500rpm. If you're running stock MAF and stock injectors you were WAAAAAAAY lean at 8psi at redline, probably 16:1+. Don't blame the TN kit, the same thing would have happened with ANY kit at that boost level. 3 psi MIGHT have been safe for you...
Pay a little extra and ship the car to a shop that knows what they are doing...
Old Jul 30, 2009 | 03:27 PM
Chef-j's Avatar
ottawa
Don't tell me you don't even want to go google.com and search their location...
Old Jul 30, 2009 | 03:51 PM
YanniXr's Avatar
Thanks man.... i already called and left a voicemail !! i will give update
Old May 27, 2011 | 10:15 AM
YanniXr's Avatar
2 year later ! got the car fixed finnally. what i did :
1. forged the pistons
2.rods
3.complete exhaust system
4. bigger injector
5.cob
6. boost controller
my car is getting tuned right now... it did 356whp at 8psi...the guy will try 12psi and 16 psi.. waiting for results!
Old May 27, 2011 | 03:55 PM
  #30
Eno's Avatar
Eno
Welcome back to the land of moving parts! I can't wait to be able to make the same announcement. I went through exactly the same issue with a shop I thought knew what they were doing because of their experience with other platforms. They probably even do reasonably well with those other platforms but with that being said the mistakes that were made were unforgivable.
I "blew" my engine too and got the bottom built- er- am getting the bottom built and going the boost control route. Got the tranny done too- no sense spending that amount of money on an upgrade just to have a car you need to handle like cotton candy.
Looking forward to hearing your final stats! Who did the build and who is doing the tune? I'm sure there are plenty in the area who would like to know.
