Vortech and now overheating
Old Jul 29, 2009 | 03:13 PM
Augy's Avatar
Quick question for you guys. I had more Vortech installed a couple of months ago. As the weather is getting hotter, my car seems to overheat when the A/C is on. When I turn it off, the car is fine. Think I have to change my thermostat? Any suggestions are welcomed....THANKS!
Old Jul 29, 2009 | 04:02 PM
Texasscout's Avatar
Funny, I would think the opposite would be true, in that, when the AC is on, both fans are working. Do you have the intercooler? You may just have more of a heat load than the stock radiator can handle.
Old Jul 29, 2009 | 04:05 PM
Augy's Avatar
Yes, I am running an intercooler, tranny cooler and stock radiator. I know that both fans are working with the A/C on. Think its the radiator??
Old Jul 29, 2009 | 04:08 PM
drifts500's Avatar
You should change radiator fluid or radiator.
Old Jul 29, 2009 | 04:18 PM
Augy's Avatar
should i buy new radiator or aftermarket radiator? or just change the radiator fluid?
booger's Avatar
I ran the T-trim Vortech and upwards of 19psi and never had a problem with over heating . You may have an air pocket in it . Also , check to see if you can see anything floating in the fluid or if its milky looking .
Old Jul 29, 2009 | 05:05 PM
Augy's Avatar
Thanks for the help I'll check my fluid or maybe I'll just take it to get drained and filled.
Old Jul 29, 2009 | 05:50 PM
Texasscout's Avatar
Yeah, there is a "burp" valve near the passenger side back of the plenum, you may just need to get the air out of the system.
Old Jul 29, 2009 | 09:38 PM
Canadian's Avatar
Canada, eh?
istan overheated with his vortech. If burping it doesn't fix it then the ambient temps may be too hot for your car in the summer and you'll need a nismo thermostat and a bigger radiator. I think that's a must anyway for any FI g/z. I used to peg my stock temp gauge in the summer here. Now with the big koyo and nismo thermostat temps are perfect all the time.
Old Jul 29, 2009 | 11:28 PM
Augy's Avatar
thanks for the help guys. i will try the burping, if not...time to upgrade the radiator and get the nismo thermo
Old Aug 4, 2009 | 11:08 PM
Augy's Avatar
well i tried the draining and changing the radiator fluid. It didn't work. So I guess its time for a new alum radiator and thermo. You guys recommed any places to buy some of this stuff at a good price?
Old Aug 5, 2009 | 07:05 PM
booger's Avatar
You sure you dont have an air pocket in the system ?
Old Aug 8, 2009 | 11:17 AM
ska12's Avatar
get an intercooler if u dont have one then get the uprev tune by osiris installed on ur factory ecu. fuel injectors, fuel pump, and that should also make it run better cause it sure did make mine run btter.
Old Aug 10, 2009 | 07:18 PM
Chef-j's Avatar
How do you know for sure if you are car is over heating or not. What was the temp?
I do not have an experience with nismo thermostat, but by research i read many people says it doesn't help.
Old Aug 10, 2009 | 09:25 PM
jtranstudios's Avatar
i would go back and bleed the coolant system the way it depicts in the factory service manual. make sure you get all the air pockets out. if that doesnt work then double check your fans and make sure they are both blowing at high speed
