HKS CAMP2 display Questions
Old Sep 2, 2009 | 12:51 AM
jonnylaw's Avatar
Originally Posted by XKR
Here you go....Use the stock nav screen for the Camp2 and GPS...or you can also install another monitor and use both.
How is your resolution and quality of display of the CAMP2 on the stock nav screen?
Mine slightly flickers and isn't as clear as when the oem nav source is displayed
Old Sep 2, 2009 | 10:15 AM
XKR's Avatar
XKR
Mine is clear.....I use the black background......The red is not as clear...
Old Sep 2, 2009 | 10:26 AM
GreenGoblin's Avatar
The goblin resurrection
Jonny if yours if flickering do you have tv and nav? It could be a ground issue transmitting noise to the screen. I also run the black background as I find it easier to read.
Old Sep 2, 2009 | 08:14 PM
jonnylaw's Avatar
hmmm. mine flickers on every background, and in analog mode, the needles sometimes go out of place
Old Sep 2, 2009 | 08:18 PM
jonnylaw's Avatar
I'm not sure of the brand that I'm using, I'll have to check. It does have a switch that can be used to switch b/w the factory nav and the camp2 source. I''ll mention the potential ground issue to my installer. Me wonders why the factory nav is as clear as day when switched, but when switching to the camp2 source, it flickers (sometimes pretty bad). Would a ground issue only cause flickering on the camp2 feed, but not the factory nav source?
Old Sep 3, 2009 | 11:10 AM
XKR's Avatar
XKR
Something is messing with the signal.....bad ground maybe
jsimonk
Dec 22, 2023 03:49 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
