5AT turbo help!!
Old Sep 18, 2009 | 05:19 AM
zeidik's Avatar
5AT turbo help!!
i have an 05 g35 coupe auto turboed. im planning to run lower then 350whp and everyone at the shop is telling me that the tranny will not hold that power. i just got the tranny rebuild with new torque converters too. im planning to run something in the low to mid 300whp. i know that the auto tranny is weaker and doesnt handle as much power but is it really that weak that it cant handle just a bit over 300whp????? im planning to get and auto tranny cooler and a valve body as well. i just need some opinions before i go ahead and spend more money on the tranny. i know i can get a manual swap but im not going to pretend and say i know how to drive stick. all manual cars iv driven all had under 150hp and i havent driven any of them for a long enough period of time to say im ready to drive a turboed G35 with 400hp. most of my friends have manual cars and they do make fun lots lol. so idk is my auto tranny really that weak even tho i just rebuilt it? and is a manual swap 100% necessary? or can that auto take some abuse if i run low boost so low 300whp? plz help!
__________________
Old Sep 18, 2009 | 05:32 AM
sayitfast's Avatar
__________________
I have a GTM Motorsports Built Auto Tranny... I run 425 whp daily no issues. I was running 352whp at 6psi on the stock tranny with a VB upgrade... no real problems at low boost for me at least.
Old Sep 18, 2009 | 10:53 AM
terrycs's Avatar
No problems here at 470 WHp with trans cooler and shift kit. No matter the power level though, it depends largely on how hard you beat on the car.
Old Sep 18, 2009 | 12:31 PM
MardiGrasMax's Avatar
Transgo valve body upgrade and a trans cooler would be all that you should need.
Old Sep 18, 2009 | 12:36 PM
da mayor's Avatar
plenty of auto guys are turbo'ed by vinnytenracing.com and have plenty of track hours/daily driving for years without issues.
Old Sep 18, 2009 | 11:32 PM
urban's Avatar
GTM tranny here also and I run over 520ftlbs of trq.
Old Sep 19, 2009 | 02:19 AM
sliderg35's Avatar
VB Upgrade and 400 hp. It's all good here.
Old Sep 19, 2009 | 02:35 PM
zeidik's Avatar
thanks guys. ill get the VB and the auto tranny cooler for my G then. im running about 7psi on a single gt35r turbo and i dont know how much power im pushing because the tranny was broken wen we were on the dyno but im sure it wont be anything crazy hard hp for the tranny.
Old Sep 19, 2009 | 03:51 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
i ran 385whp and 373ft/tq w/no vb or built trany and it was smooth and no problems w/the trans..guess it just depends on the car
Old Sep 19, 2009 | 05:09 PM
Canadian's Avatar
Canada, eh?
You just said you had the tranny rebuilt. Did you build it with the high performance Alto clutch packs or did you just do a OEM rebuild?
Old Sep 21, 2009 | 02:16 AM
zeidik's Avatar
OEM rebuilt. it was an old tranny even tho it was mostly hwy and i put most of it on non turbo. i maybe put about 5k on it with the turbo. then on the dyno my tuner couldnt bring the boost down from 20psi 500whp+ so we took the boost controller off because it wasnt working and just tuned it with the haltech and timing. not to sure how he tuned it precisely but he said the car makes about 6-8psi now. but on the few runs he tried to bring down the boost it probably hurt the tranny.
Old Sep 21, 2009 | 10:20 AM
phunkenstein's Avatar
Get a VB Upgrade jsut to be safe.
Old Sep 21, 2009 | 12:47 PM
rcdash's Avatar
That's too bad - you could've gotten the high performance rebuild kit for literally the same price. The expensive part is the labor. With a VB and cooler you should be fine for a good long time though. Get a really big cooler, 11 x 11 x 1.5" or thereabouts.
g.spot
May 9, 2016 10:54 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
mikemf8
Sep 3, 2015 08:01 PM
