need help with vortech tuner kit
Old Nov 19, 2009 | 11:32 PM
856_reilly's Avatar
Angry need help with vortech tuner kit
i ordered a tuner kit i need to know what i need after i get this to finshed it right before i tow it to the tuner. ive been getting alot of mixed info. the tuner said a walbro fuel pump and somthing the ive been searching for is he said i have to modify the sending unit does anyone know what that means????? or do i have to really have to do it???? im lost. also are 440cc injectors good enough? and the management system, ther useing up rev is that the system or no? im lost please somebody let me know i just feel like there tryin to get money out of me!!!! also what kind of plugs do i run??
Old Nov 20, 2009 | 03:28 AM
bigc's Avatar
Wings Nation
this thread will answer a lot of your questions:
http://my350z.com/forum/forced-induc...questions.html
Old Nov 20, 2009 | 03:40 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
i believe you will need Fuel Pump, Injectors, and some sort of engine tuning software whichever you decide to go with.. correct me if im wrong guys
Old Nov 21, 2009 | 01:22 AM
856_reilly's Avatar
Thumbs up the vortech help
thanks bro! any ideas on a set of headers tryin to make a choice and dont know which one are good
Old Nov 21, 2009 | 01:26 AM
Really Needs a Life
headers on a g35 = waste of time
Old Nov 21, 2009 | 01:36 AM
Kris79's Avatar
battle froggy
it does make a pretty noise though lol
Old Nov 21, 2009 | 01:38 AM
Really Needs a Life
^true..
Old Nov 21, 2009 | 05:21 PM
856_reilly's Avatar
Smile headres a no????????
k cool so basically ill b wastin my money? so with the vortech tuner kit,injectors, the walbro fuel pump,test pipes, hks and a tune i should be good?? hit me up and let me know please thanks for the help!!!!!!!!!!!!!!!
Old Nov 22, 2009 | 04:53 PM
liche's Avatar
With someone who just had this done and has done EXTENSIVE research, you'll need the following:
1. Vortech Tuner Kit
2. New Injectors (440cc minimum) - I went with DW 600's
3. Walbro Fuel Pump lph255
4. High Flow Cats or Race Pipes (Stock CATs are NO GOOD!)
5. 1-Step Colder Plugs
6. Engine Management (like Osiris etc...)
RECOMMENDED:
1. 3.12 pulley (will give 10psi boost)
2. A/F Wideband Gauge, Boost Gauge (Oil gauges if you are using blower that shares engine oil )
One of the most important things that I overlooked initially, was the need for the High Flow Cats. The engine is tuned rather rich for FI and it just kills and clogs up your stock cats. So you need to dump them.
My car is finally to the point where I'm really happy and i'm producing about 410rwhp with a Vortech (with above mods) using the 3.12 pulley.
Old Nov 22, 2009 | 04:55 PM
liche's Avatar
Also, i've been told the 440 cc injectors are good to at least 400whp.
Oh, and if you already have a plenum spacer, get rid of it. These tend to leak when the manifold is under pressure (boost), so they are typically only good for NA vehicles.
Old Nov 22, 2009 | 10:45 PM
856_reilly's Avatar
Thumbs up help with charger
thank again bro let me know about the bigger pully im thinkin i should just do right from the door cause im goin to b gettin it tuned just want it to b safe ya know!!! Didnt know you were from philly im right over the bridge! Jersey!!
Old Nov 23, 2009 | 07:39 AM
liche's Avatar
Cool. If you're from Jersey, than definitely check out JT Performance in wilmington, DE. They do the Uprev tune and are very good at what they do.
Old Nov 23, 2009 | 02:47 PM
Silencer_0's Avatar
Isn't 410 HP kinda pushing it for a stock block? Also wouldn't you need an oil
and tranny cooler? Or am I getting confused with a turbo set up......
Old Nov 23, 2009 | 02:53 PM
Really Needs a Life
^depends on how "safe" you want it to be.. eventhough Fi is a roll of the dice. you can get a tranny cooler but its personal preference. and the 410whp # is fine, it just depends on the tune, imo i think 410whp on a vortech would be "more reliable" than a 410whp turbo tune.. it just depends on how good the tune is
Old Nov 23, 2009 | 06:03 PM
Silencer_0's Avatar
Ah I see, thanks . I'm still trying to decide if I want to go with a sc or tc setup. That my350z link posted has some great info.
