mountin da BOV
Old Feb 19, 2010 | 09:48 PM
nyqueenz's Avatar
mountin da BOV
where did you mount yours.. before the MAF I.E. charge pipe or after the MAF on the intack side?
Old Feb 20, 2010 | 10:14 AM
suprasam's Avatar
Mine is mounted on the charge pipe.
So the order to the engine is intercooler, bov, MAF, throttle body.
Old Feb 20, 2010 | 12:15 PM
sliderg35's Avatar
Same for Me.
Old Feb 20, 2010 | 12:56 PM
djamps's Avatar
Wherever you put it, you better put it before the MAF or else the MAF won't be reading correctly. Think about it... air is goin through the MAF then out the BOV...not good.
Old Feb 20, 2010 | 04:05 PM
ttrank's Avatar
Grocery getter
Yep.
Post intercooler and as far from the MAF as possible.
Old Feb 20, 2010 | 05:13 PM
superchargedg's Avatar
Same here.
Old Feb 23, 2010 | 05:07 AM
nyqueenz's Avatar
very true.. however, when u go full standalone there will be no MAF correct?
Old Feb 23, 2010 | 05:08 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
im gonna be the 1st to ask but have you done research/if any on FI?
Old Feb 23, 2010 | 06:24 AM
dann1313's Avatar
you always need a maf. an ecu or ems or whatever computer you use still needs the maf to read the air flow..
Old Feb 23, 2010 | 10:28 AM
djamps's Avatar
It's possible to have just a MAP (instead of a MAF) but you'll need one or the other. MAF based tuning is usually more 'streetable' than MAP, but either work ok as long as the EMS supports one of them.
In fact the UTEC is unique in that it used both MAF and MAP for FI (switches between them in/out of boost).
Old Feb 23, 2010 | 05:35 PM
eZg's Avatar
eZg
Don't mess with Lance
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
hyperlitesmu
Forced Induction
Aug 22, 2005 04:06 PM
G-Mann
Forced Induction
Mar 13, 2005 06:33 PM
