DYNO
Old Oct 9, 2004 | 08:17 PM
gumpdriver's Avatar
Montgomery's Finest
DYNO
Do different dyno's put out differant #'s or does it depend on the coditions.
From me to U suck my exhaust
2003 6Mt
Val 1,Stillen slotted rotor,Injen cai,Double din,Memphis SHP 10',Hotchkis Sway Bars and Volk GT-C's 19in surrounded by Toyo T1's
Old Oct 9, 2004 | 09:25 PM
SFLG35's Avatar
FGC President
Re: DYNO
yes
Daniel
where are my GTC's this time? well the fronts are here but where the hell are the rears? o i almost forgot. they forgot to ship them. this is really pissing me off now.
Old Oct 10, 2004 | 10:01 AM
gumpdriver's Avatar
Montgomery's Finest
Re: DYNO
I dynoed the other day on my GT-C's and i got MAX 218 hp and MAX 215 torque i do not know if this is good or bad need some info. I was on a dynojet dyno. Temp 82.8F
2003 6Mt
Old Oct 10, 2004 | 11:04 AM
gspot35's Avatar
Re: DYNO
That's what I got on my 03 Sedan AT with plenum, stillen exhaust and injen intake. a:f was avg of 13.5:1
Check out my group buy for Torque Converter and Valve Body upgrades on my350z.com
Old Oct 11, 2004 | 05:53 AM
neffster's Avatar
Re: DYNO
1. Your heavy wheels are hurting your hp and tq numbers, for sure.
2. Do you drive a coupe or a sedan (sig only says 6MT)
3. Did you use SAE corrections on the dynojet?
4. The dynojet *might* not be calibrated properly...
5. The numbers seem low, do you have any other mods?
Old Oct 11, 2004 | 08:04 AM
Q45tech's Avatar
Re: DYNO
Since tires are the greatest loss item [>5%] in translating flywheel to rear wheel power, this is the greatest source of variation
[brand,size, inflation, rear alignment, temperature].
Measure the heat rise in drive train components and you will find the different losses: [diff 3%], drive shaft 1-2%, half shafts and bearings, gears 1% per mess, clutch, slight rear brake drag, fluid frictions, etc.
Old Oct 11, 2004 | 03:12 PM
ChicagoX's Avatar
Don't drink and Mag Race
Re: DYNO
Hey Q,
Could you please post your reference to the statement regarding the tires being the greatest driveline loss in a dyno setting? (greater than 5% of total losses)
Thanks.
'04 G35X Graphite/graphite, NAV, wood, premium
"May you lead an interesting life..." -- Old Gypsy Curse
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
