Used Turbonetics Single Turbo Kit
Old Nov 23, 2010 | 04:16 AM
josh.irvine.6's Avatar
Hello,
I just purchased a 2nd Hand Turbonetics Single Kit, less then 5000k. I am getting a full custom Greddy exhaust, and UTEC EMS with the system. I know there are issues with the Turbos going and engine, but I want to try it anyway.
I am thinking about getting a oil spacer kit as well.. anything imparticular this kit is lacking that I should get to have a safe install? Thanks
Old Nov 23, 2010 | 06:07 AM
Junkyardspecial's Avatar
I had bought this kit to do the same as you with a planned turbo replacement int he future, It installs well and I have had no problems at all. Good luck with it!
Old Nov 24, 2010 | 05:38 PM
woRthy's Avatar
i have the same kit for sale, get the oil pan spacer that has turbonetics fittings, its on intense power... umm they also have high intake temps so a aem water/meth is awesome for them, i put 415whp with mine
pm me if you have anymore questions
Old Nov 24, 2010 | 05:41 PM
PM Sent! Thanks
Old Nov 29, 2010 | 07:10 PM
856_reilly's Avatar
Thinking of going turbo. Single or twin? A friend is telling me single. I'm clueless tho. Running a vorteh now. gonna be doing my motor this winter and i want to do it rt. Any suggestions?
Old Nov 29, 2010 | 07:13 PM
Frankieg35's Avatar
Don't thread jack buddy.. Make your own.. haha keep your supercharger!!
Old Nov 29, 2010 | 07:35 PM
856_reilly's Avatar
lol you are such a forum *****!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!! lol na frank i'm doin it i'm doing it rt F- it!!!!!
Old Nov 29, 2010 | 08:35 PM
Frankieg35's Avatar
Haha!!
Old Nov 29, 2010 | 08:43 PM
1hotvq's Avatar
Originally Posted by josh.irvine.6
Hello,
oil spacer for sure, and heat wrap all pipes (even charge pipes) cause the temps in the engine bay get high. there are insulation wraps for intake pipes i used that dont actually look to bad i got from mopac.
Old Nov 29, 2010 | 09:13 PM
Awesome. Thanks alot. I am definitely going to get the spacer, I am thinking of upgrading the injectors from the 380cc they came with to 440 or 550, but I don't know if I need to because I don't plan on boosting past the 8/8.5 max thy the MAF sensor can handle. Or should I get the MAP sensor anyway?
Also, should I be getting an oil cooler? If so, recommendations? As for wrapping my pipes, I will be doing that for sure, how much insulator do I need roughly? And lastly, should I also plan on getting 1 Step Colder plugs? If so, recommendations?!
Thanks alot guys.
Old Nov 29, 2010 | 09:34 PM
1hotvq's Avatar
Thanks alot guys.
i went with detaschwerks 600cc injectors and ngk 1step colder plugs, but if your staying at 8.5lbs of boost 440cc should be fine. as for oil cooler you dont need it but it wouldnt hurt. i have a map sensor on my utec and the transition point on it from maf to map really sux! dont get if you dont have to. i used one full roll of heat wrap for exhaust and a full turbo insulator kit then wrapped the charge pipe around the turbo cause of the heat exchange there (one full sleeve).
Old Nov 30, 2010 | 03:33 AM
Perfect. I guess i'll be upgrading the injectors then, just to play it safe, and I'll be sticking with my MAF instead of buying the MAP. And thanks for the info about wrapping everything up, better safe then sorry, right? Question, I'm assuming that I should replace the gaskets right? Kind of a one time use deal... arent they? If so.. how many are there, do you know? I'm having a hard time finding out from the companies that sell them, customer service isn't really making an effort for me...?
Old Nov 30, 2010 | 10:46 AM
1hotvq's Avatar
im guessing you mean exhaust gaskets. ya i would replace them on the wastegate for sure. i think there are 4 for the wastegate. my tuner had these in stock. if you take the gaskets to a parts store they would be better to point you in the right direction. i reused my old exhaust manifold gaskets cause they are quite good. also check the old ones for any leaks (black carbon build up on gaskets) and make sure you replace and tighten them up better.
Old Nov 30, 2010 | 03:32 PM
escobar929's Avatar
i would ditch the utec and go haltec
Old Nov 30, 2010 | 05:17 PM
Why?
