Vortech idler pulley question
Old Mar 9, 2011 | 11:08 PM
1FSTG35AT's Avatar
I tried searching and I found a part number and I just need someone to confirm this for me...
My supplied smooth idler pulley bearings have finally worn out and I found that dayco sells pulleys that will work. Is the part number for it from dayco 89005?
Thanks
Old Mar 22, 2011 | 06:34 AM
andrewstclair's Avatar
what pulley are you talking about the smooth factory idler or the one on the vortech bracket? the vortech idler has a snap ring you can remove and push out the bearing and put in a new one the universal bearing number is on it.
Old Mar 22, 2011 | 08:57 AM
ratm68's Avatar
my smooth idler has sidewall to keep the belt on track. If your's has sidewalls also, then that part number is incorrect. When googled, it showed a pulley that is completely smooth. I think the size of the pulley is correct (76mm). Just go to and auto parts store and ask them for the dayco pulley catalog and tell them you need a 76mm pulley for 6-rib belt. there is probably only 2-3 variation of the smooth idler pulley to pick from in that size. goodluck
Old Apr 6, 2011 | 09:28 PM
josahn's Avatar
what does it mean when my belts are squeaking on my super charger.
Old Apr 12, 2011 | 06:37 PM
show2nite's Avatar
It means you're experiencing belt slippage.
flytim3
Jul 29, 2016 10:17 PM
EricF
Aug 28, 2015 08:27 AM
linedr89
Aug 17, 2015 05:11 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
