Exhaust and FI
Old Nov 10, 2004 | 03:53 PM
KPierson's Avatar
Exhaust and FI
Well, I've finally got the itch to do my exhuast. I've had the stock exhaust ever since Crawford Z installed my Procharger, headers, plenum, and high flow cats. I want to do from the Y-Pipe back but I havne't heard anyone talk about what systems work well with FI. I want something that will let the engine breath as much as possible so I'm considering a dual but I'm not really sure. What do you all think?
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Nov 10, 2004 | 04:52 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Re: Exhaust and FI
the way i understand is, you don't want free flowing exhaust with FI because you want back pressure for vacuum purposes...I may be wrong, but others can chime in.
Wanna see mine?
Old Nov 10, 2004 | 05:11 PM
KPierson's Avatar
Re: Exhaust and FI
well, I am by no means an expert.....
are you sure its vacuum and not boost? You will definately lose boost with a bigger exhaust, and possibly vacuum too, but I have never heard that. I know when you force air in you have to have some place for it to come out. And when you are planning on running 16psi you can afford to lose a little backpressure to allow more air to flow.
Kevin
AIM: KPiersonTec
Old Nov 10, 2004 | 06:40 PM
GMADD's Avatar
Re: Exhaust and FI
If you go turbo then you would need a free flowing exhaust to have the gases exit faster.... but with a supercharger, you will loose boost so it all depends on what you need.
Tasso-
Old Nov 11, 2004 | 11:41 AM
ChicagoX's Avatar
Don't drink and Mag Race
Re: Exhaust and FI
I think the reason people are losing boost with large exhaust systems has more to do with our stock cam timing than anything else.
With our torque-promoting overlap, boost is literally being pushed out of the cylinder under high PSI.
I believe that a cam change to something more targeted to FI would allow for more gains by going to a larger exhaust system.
Just my $.02
'04 G35X Graphite/graphite, NAV, wood, premium
"May you lead an interesting life..." -- Old Gypsy Curse
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Albanian122
Sep 12, 2015 04:02 PM
