Gauges which ones needed for FI?
Old Nov 16, 2004 | 12:51 PM
Dsskyline's Avatar
What gauges do you guys recommend that you must have in order to know what your car doing? (boost, EGT, oil, water, A/F or any other gauge needed) Which ones are not really needed or that important? Does anyone know where I can purchase DEFI gauges or anything better? Thanks
2004 DP 5AT Borla exhaust, UR crank pulley, V4 kinetix plenum, kinetix cats, z-tube, stillen cab, TS reflash, GTR overlays
Old Nov 16, 2004 | 06:35 PM
KPierson's Avatar
Re: Gauges which ones needed for FI?
Air/Fuel is a necessity. Boost is nice to have, just to make sure everything is working right. Those are the only two I have. Some people claim EGT is important too, but if everything is working right then it won't be very critical. Depending on what FI you go with fuel pressure could be very important, esecially if you are using an aux pump or aux injector.
Nothing else is really important. Keep in mind that I don't race my car or run it hard for extended periods of time. If you drive the car very hard for long periods other temp guages may be important.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Nov 16, 2004 | 06:59 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
instead of GAUGES...go with a Zeitronics unit...it tells you AF and boost, as well as EGT if you want, for around $500 and it has a small display and keeps your car stealth! That's what I'm going with.
Wanna see mine?
Old Nov 16, 2004 | 08:10 PM
Dsskyline's Avatar
Where can I find info on the Zeitronics unit Randy? Thanks
Old Nov 16, 2004 | 08:11 PM
Dsskyline's Avatar
Thanks for the info Kevin.
Old Nov 17, 2004 | 11:24 AM
a.k.a. RANDYS_G
http://www.zeitronix.com/Products/zt2/zt2.htm
Wanna see mine?
Old Dec 4, 2004 | 08:20 PM
yeahi's Avatar
I have an Oil pressure gauge, Boost/vacuum gauge, and a air/fuel gauge. As for those defi gauges, theyre like 250 a piece but they're so nice. They have them at www.optauto.com they have the gauges there. Some people also choose to just go autometer, and get either the mechanical or electronic gauges. There are also the other options like Blitz and greddy gauges. Some also say EGT is important, but i don't have one. I do have a program that plugs into my OBDII scan port that reads off everything in real time (speed, EGT pressure, IM pressure, varions temps.) its a nifty device but kinda bulky.
Devon
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
wonderizm
Sep 24, 2015 03:09 AM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
.cakestar
Aug 4, 2015 09:05 PM
TWASkyliner
Aug 1, 2015 11:43 AM
