what is the best turbo kit to buy?
hello everyone i was wondering if i could get a little information about some turbo kits and mods. I drive a 2004 g35 6mt coupe with JWT popcharger and top speed pro 1 full exhaust. im trying to gather information on what is the best SINGLE (not twin turbo) turbo kit to buy for a stock engine, using pump gas and can be used for daily driving, along with which forged pistons to use ( other mods listed to help the performance is appreciated as well). i dont really have a price range right now just looking for information for the future. my goal is to get around 400-500 hp with a turbo and slight mods and as time goes on build it more and add more HP. if you have a turbo kit on your car and you would recommend it please post what it is, what mods you have done, who tuned it, how its working for you and how much HP it produces
thanks guys
thanks guys
Start here this list has alot of good info but the single turbo kit list is way out of date and the APS and Turbonetics kits are no longer readily available and the Turbonetics kit has been proven to have many issues with it.
https://g35driver.com/forums/forced-...ion-noobs.html
Although not on the list above The best single tubo kit by far is the Boosted Performance kit, it is the most affordable and easiest to instal and uses all high end parts and has several turbo sizes available to meet your power needs. PRivate Message 350Z T on here he builds and sells the BP kits.
Don't be afraid to read the threads in the FI section either people will be more willing to help if you put in a little effort and do some research and ask some intelligent questions. If you do that you will find OEM pistons are not your weak point.
How much $$ do you have to play with? 400whp (stock block limits) is pretty easily attained, any kit will get you there and all you'll really need along with it is a fuel pump, larger injectors and a beefier clutch along with a good tune.. Anything more than that becomes very invasive and very expensive very fast. Do some research and know what you're getting into!
In the end it all comes down to your end goals and budget
you will be getting a PM shortly sir.
Not trying to dissuade you from going this route just want to be realistic with what can and DOES happen, most of the time when this happens tho people don't post about it on the forum, we only see the success stories and the builds in progress.
I'd really consider finishing up with bolt-ons, an uprev dyno tune (not the email one an actual in person tune on a dyno) and some decent suspension to help the handling, and then reassess. Besides, if you do go FI you're going to need all that anyways. I was boosted on stock suspension for a little bit and it was noooo bueno
If you're not ok with throwing every penny of that in a fire and watching it burn before your eyes don't boost your car. Even with the best kits and best tunes $@%# happens and some motors just can't take it. Some guys throw on a twin turbo kit in their backyard and boost like crazy stock block for 50K miles without even a proper tune and other guys watch their car go boom on the dyno without even sitting behind the wheel.... and if that happens you'll end up throwing in at least another 10K or scrapping the car.
Why would you be buying bolt ons now if you plan on goin FI later. That is just a waste of money IMO. You can upgrade your clutch and tires now, but don't waste your money on plenum spacers, intake systems, exhaust systems..ect.
Since you are in NY, your best bet is to see Vince at R/T tuning. The man knows his stuff very well, and has tuned countless VQ's.
