Questions about using the stock MAF on turbo'd G35?
I imagine in some small part, yes. But not sure to what degree.
Then again, I'm about as far from an electrical engineer as you can get. About the extent of my electrical expertise is: "Electricity runs on smoke... if you touch the wrong two wires, you let the smoke out. And then sh*t stops working."
somehow i have my stock MAF and have 571whp. Fully built stage 1 motor and upgraded 700bb JWT tt with heir flywheel and clutch, running on the Split second box that came with it.
Unless they changed the maf,didnt tell me, and did it for free lol.
Dyno video to prove.
so should i get the hps? it will work with my ss box fine im sure. But id really like to get osiris, except i was told id need to switch my 550cc injectors and 255lph fuel pump to 1000cc and 400lph as well as new fuel rails.
any input? Seymore has been awesome, just also curious as to anyone elses first hand.
My car has a misfire code and in full throttle it hiccups and kinda bucks from fuel cutting off it seems like, the AF meter drops below 10 and the lines on the screen comes up. please help lol. PM me please if you dont mind.
ty in advance!
ty in advance!
![Name: 20130602_001638_zps8060d16b.jpg
Size: 97.6 KB](https://g35driver.com/forums/attachments/forced-induction/200646d1501315315-questions-about-using-stock-maf-turbo-d-g35-20130602_001638_zps8060d16b.jpg)
Sounds like when my charge pipe separated on The passenger side. Worth a shake on your piping across The board before you flood a cylinder.
I just had the same thing happen on my 700bb. I have the 350z version of the kit but I'm told that pipe over The front p side wheel well is prone to separation.
A quick shake was all that was needed but I thought it was something deeper so never even checked. Drive to The shop and came close to flooding the cylinder. I barely even know what I just said but the sub 10 afr I was getting supported the possibility.
Good luck
Good luck
I'm just excited to pass on lessons learned but yes something is amiss.
Oh no man I was all over it.
And somehow Osiris needs him to change to 1000cc injectors and 400 pump to support his power claims while this ss box has been contended by nearly half that?
There was an annecdote that I really enjoyed about how if you ever found yourself lost in the woods-just pull out a deck of cards and start playing solitaire... Because it never takes long for someone to find you and tell you where you should put that 4 of diamonds.
Now I think the way I will tell it is if you find yourself lost in the woods just shout out loud that you have a 700 kit and make close to 600hp on 550 injectors and a 255 fuel pump and watch the masses plow down the trees to correct you
seymore4 (06-05-2013)
#30
