Oil Pressure Sensor Hook up
Old Jul 18, 2012 | 09:12 PM
dvandriesen's Avatar
Installing Oil Pressure gauge and wonder what everyone uses to connect the gauge. I know i can get a Oil filter sandwich or the t fitting adapter. Leaning towards the sandwich just not sure if they make one with a female 1/8 bspt which our senser screws in or if you have to use a 1/8 npt to 1/8 bspt to install a sandwich. Any help would be great have searched for a while.
Old Jul 19, 2012 | 02:32 PM
ratm68's Avatar
I've been using the Glowshift sandwich plate (ones for oil cooler w/gauge port) and they work well. I replaced my ebay aluminum plate which leaked with these are they have been solid. These comes with 3 port for sensors.
http://www.glowshiftdirect.com/Oil-F...-Adapters.aspx
If you're planning on building an oil cooler down the road, buy these and simply plug the gauge to it.
http://www.glowshiftdirect.com/oil-c...-adapters.aspx
Old Jul 19, 2012 | 06:17 PM
Thanks picked up the first one you listed last night with a 1/8 npt to 1/8bspt adapter to hook the factory sensor into.
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
TWASkyliner
Aug 1, 2015 11:43 AM
