"TM" Vortech Belt Mod - Interest Thread
Old Jun 24, 2013 | 08:25 PM
ge35es's Avatar
just a thought... wouldn't providing more belt capture on the jackshaft pulley be a better solution ?
im noticing the alternator doesn't have much capture either.
ive run into this issue several times on engine transplants etc. with more belt capture the tension wont need to be as tight and the belt will last longer
Old Jun 24, 2013 | 08:54 PM
TunerMax's Avatar
G35
By "capture" do you mean how much of the circumferance has belt on it? If so, the jackshaft pulley actually has a very reasonable amount of 'wrap', IMO. More than most pulleys I've seen.
Old Aug 3, 2013 | 06:28 PM
speedk1ng's Avatar
Finally got mine installed.....going to start it up in a few minutes and see how things go:
--Sk
Old Aug 3, 2013 | 09:15 PM
TunerMax's Avatar
G35
nice bud good work! you may have one issue unless your belt is tighter than it should be though, the Allignment is just a bit off and when the belt stretches it might contact the timing cover. hope it works out, worst case you just need to re drill the dimple to "clock"it a bit the other way
Old Aug 3, 2013 | 10:48 PM
speedk1ng's Avatar
Actually I'm fine in clearing the timing cover.....but the serpentine belt jumps 2 grooves at the jackshaft for the supercharger with the tensioner installed.
Remove the tensioner and install the idler pulley, the serpentine stays put.
Old Aug 3, 2013 | 11:26 PM
TunerMax's Avatar
G35
did you shave the back of the variable tensioner flat?
TunerMax's Avatar
G35
and you won't notice the clearance issue until the belt stretches under high rpm and high load
Old Aug 4, 2013 | 12:59 PM
speedk1ng's Avatar
yes....and checked that it's flat with a straight edge....
Old Aug 4, 2013 | 01:00 PM
speedk1ng's Avatar
I left adequate room for the belt clearance with the timing cover for belt stretch....but the belt jumps grooves on the jackshaft pulley immediately at idle.
Old Aug 4, 2013 | 01:08 PM
TunerMax's Avatar
G35
nice dude looks good, well something isn't lined up obviously and unfortunately, so check the belt alignment, not sure why you are having an issue if you preset the tension and the belts are aligned
Old Aug 4, 2013 | 03:08 PM
speedk1ng's Avatar
Thanks...I don't have any more time to mess with it this weekend. I put the grooved idler pulley back in and tensioned the belt manually. Runs as it should.
I'll come back to the tensioner when I get some time to play with it.
Old Aug 4, 2013 | 05:27 PM
TunerMax's Avatar
G35
post back!
fyi to onlookers: I just gave speedk1ng a quick parts list and very rough instructions via PM to help him do this mod himself, he is not actually having trouble with a kit. I have not produced or sold a kit
Old Oct 13, 2014 | 09:58 AM
ge35es's Avatar
noob question...
which pulley is doing the squealing ?
im seriously looking at this kit and gathering info
Old Oct 14, 2014 | 11:51 PM
TunerMax's Avatar
G35
Not really a noob question, as it's not specifically a pulley, but rather the belt itself. The most common reasons are the alternator loading up, A/C compressor loading up, and Power steering, same thing. It's not uncommon for all 3 of these to load up around the same time usually on cold starts and parking lot manouvering.
The second part is belt slip caused by the supercharger loading up, which doesn't tend to be an obvious squeal, just a loss of tension and boost
Old Mar 23, 2015 | 01:40 PM
  #30
speedk1ng's Avatar
Dredging this up from the dead......but I spent a little more time to understand my issue with my belt walking forward on the jackshaft pulley. I think I have a resolution in place, but it will be a bit before I have some other projects complete and can start the engine to see if all works.
I'll post up once I get it started......
