compression
Old Dec 26, 2013 | 09:28 PM
tizzy56's Avatar
compression
whats is a good compression for going boost on a 2004 G35 6 spd manual?
Old Dec 27, 2013 | 10:02 AM
rcdash's Avatar
http://www.turbobygarrett.com/turbob...tio_with_boost
Old Jan 3, 2014 | 10:23 AM
silencedeyes's Avatar
if you DD the car and plan on running pump gas stick to 8.5:1
Old Jan 4, 2014 | 01:58 AM
N8Deezy's Avatar
I raised mine up to 9:01 from 8.5:1and really enjoy the response.
Is your suggestion of 8.5:1with respect to the pump gas?
My cars performance isn't too bad with pump. But I introduced too many new variables to be more accurate for comparative sake.
Last edited by N8Deezy; Jan 4, 2014 at 01:59 AM. Reason: Apparently using : gives you a band with numbers haha
Old Jan 4, 2014 | 08:40 PM
huh? you have a low comp motor already?
Old Jan 4, 2014 | 08:44 PM
N8Deezy's Avatar
Yea I HAD low comp pistons. One of them cracked under boost.( long story)
So this time around i went with JE low comp pistons.
In short to answer your question yes I have a low compression built motor
Old Jan 4, 2014 | 09:16 PM
Then you're good. So why the question? I'm sure you've read the hundred build threads here and know what most are using.
Old Jan 4, 2014 | 09:30 PM
N8Deezy's Avatar
I'm not the OP. I was curious as to why for a dd you would suggest a compression ratio that offers less torque on the low end.
Old Jan 4, 2014 | 09:46 PM
It's a safer choice when using 91 or 93
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
yosip1115
16
Sep 28, 2015 04:14 PM
