i have vortech sc with utec piggyback. few days ago i've cleaned my throttle body cause i was having hot start issue and forum recommend that i should clean the throttle body. after it was cleaned, i've connected back to the car and tried the manual idle relearn process about 40times( it would drop to 650rpm, but soon as i restart the car it will jump to 1200rpm and stay idle around 900rpm), so i have not been successful. i took it into the dealership and they said they cant relearn cause of the piggyback. my question is can tuning shop able fix this issue with retune or maybe i have to install a new throttle body? someone said if i install a new throttle body i wouldn't have to perform throttle body relearn process is that true? any info would be greatly appreciated
PAIXAO
close
- Join DateSep 2008
- LocationThe Commonwealth
iTrader Positive Feedback100
iTrader Feedback Score(14)
Liked:445 Times in 316 Posts
Did you move the throttle body plate while you were cleaning it? These throttle bodies are very sensitive and if you didn't follow proper procedures you will need to replace it.
Quote:
I did move the plate to clean in between. Do you know if I change out the throttle body I have to learn the pattern or would it work without learning?Originally Posted by PAIXAO
I think after it drops you need to turn the car off and then immediately turn it back on. I had that problem as well and I think that fixed it.
Quote:
Cool, I'll try that. ThanksOriginally Posted by coffeysm
Quote:
I tried it, but still not saving the idle.Originally Posted by coffeysm
PAIXAO
close
- Join DateSep 2008
If you've purchased a new throttle body you must do the relearn process.
Quote:
I'm at Infiniti dealer now, we'll see. I have a question would utec conflict with throttle body relearning process?Originally Posted by PAIXAO
PAIXAO
close
- Join DateSep 2008
That I unfortunately cannot answer. I can't imagine it would as your throttle body was fine prior to cleaning. Best of luck to you.
There is a re-learn process. I did it and worked....
Click here
Be patient, may take several times to get it right
Click here
Quote:
I've done that 40times and I took it into dealer and wasn't able to fix the issue. I had to buy a new throttle body and they were able to relearn it.Originally Posted by Duriisimo
There is a re-learn process. I did it and worked.... do a search..
Takeaway is not to clean your throttle body or don't move the butterfly when you are cleaning it. It cost me new throttle body and labor to relearn it. Good lesson learn
Quote:
You are one of those lucky case. It did not work for me and even dealer wasn't able to use consult lll to salvage my old throttle body. Oh well it's just my luckOriginally Posted by Duriisimo
I moved mine while cleaining it and did the re-learn and fixed it
