guide to the rev9 turbo kit
Old Nov 15, 2019 | 08:45 PM
William McInnis's Avatar
low and slow.
Unfortunately part of a custom build.
How did you get the AC lines to work they are right in the way of then pipe that goes from down pipe to waste gate. I got the z1 lines and it seems they are right in the way.
Old Nov 16, 2019 | 12:38 AM
yag's Avatar
yag
I had no issue running this ac line. Can you send me a pic of what issue youre having?
Old Nov 19, 2019 | 04:56 PM
low and slow.
So I said **** it blocked off that port and went open dump for wastegate. Was tired of fighting it.. I did get the invidia n1 exhaust had to have a custom 6 in extension pipe made so just be aware if anyone gets that exhaust the 8 will not work. I had it done with flex pipe as well as the turbo kit comes off straight and the invidia has a slight angle to it. I still have 1 vband leaking the front of that y pipe you had to cut. Ordered a 2.5 in it was to large. Got a 2.0 in on the way let's see. how that fits. This kit is not for the light hearted. I am 99% done and it was a pain in the *** to install. Here is a pic before I tighted down everything and put on the custom link pipe
Old Nov 20, 2019 | 02:11 PM
yag's Avatar
yag
Oh thats what you were talking about, my bad. I went open dump too. I have been getting a lot of boost creep so im gonna relocate my wastegate and upgrade to a 44mm once my stock block finally gives way.
Old Dec 14, 2019 | 05:28 AM
low and slow.
Still fighting me.
The down pipe was eating o2 sensors. So finally bit the bullet and went full stand alone link ECU Xtreme. No more o2 sensors no more maf full 4 bar map and iat sensor now. Hope to throw it back together and let's see how she runs.
Ca
STIsaad
Engine - Power Adders
Dec 5, 2020 02:39 AM
sillief00l
Jul 22, 2010 09:43 AM
Marcelz
Archived Sales
22
Oct 17, 2007 05:08 AM
tgenius
Dec 16, 2005 07:27 PM
