APS G35 Twin Turbo System testing - awesome
Old Mar 22, 2005 | 04:56 PM
  #122
aps's Avatar
aps
Originally Posted by KPierson
Keep in mind, that its not only the turbos that factor in to max power, all though they are most likely the most expensive part.
100% true Kevin and this is why APS engineers matched the Garrett GT series ball bearing turbos to support around 800 Horsepower, this makes it much less expensive for the guys who want to produce big power down the path withiout having to replace the base turbochargers.
The intercooler will have a max hp rating also, the piping will effect max hp,
Again very true Kevin and the APS intercooler core will support very high power with a minimal pressure drop, around 800 HP with a small pressure drop of approx 1.5 PSI only, all good.
Peter
Old Mar 22, 2005 | 05:04 PM
  #123
aps's Avatar
aps
Originally Posted by GurgenPB
Oh man... can't belive that it took me 4 days to find this post... so sorry... I just climbed out from under a rock (my final exams were brutal)...
Man, I would definitey love to be able to fly down for this.... seriosuly... I think I might be planning to visit australia this summer... and if i did, i would certainly stop by... gosh... I wish my car was done already...
Gurgen
Good to hear from you Gurgen and I hope all went well with yout final exams, glad I'm well past that time of life.
Would be excellent if you make it down to Oz for a holiday then we could go for a good blast together in the G35. I tested the TT G35 last night with just over 510 WHP and the G35 feels awesome with this power, not sure how long the stock clutch will cope with the huge amount of torque though.
let me know how your G35 is coming along when you get a chance.
Thanks
Peter
Old Mar 22, 2005 | 09:50 PM
  #124
aps's Avatar
aps
Hi Guys,
Just for kicks, we've placed a sound/video clip of the G35 with the APS exhaust with test pipes on the APS web site - http://www.airpowersystems.com.au/350z/g35/g35.htm and the link is under the 3rd dyno graph (470hp). The exhaust note is awesome when you get stuck into it but quiet when free revving at cruise. On the road, it makes you want to drive with the windows down regardless of how cold it is.
Hope you enjoy.
George
Old Mar 22, 2005 | 10:39 PM
  #125
zero2prove's Avatar
Originally Posted by aps
Hi Guys,
Hope you enjoy.
George
Is it me or does that exhaust sound different than the APS dual fitted to the 350Z? I guess it sounds a little different on video, still awesome.
Tuan
Old Mar 23, 2005 | 10:23 AM
  #126
tony's Avatar
Tuan
I agree, it does sound a little more aggressive than the 350Z exhaust.
Old Mar 23, 2005 | 06:13 PM
  #127
aps's Avatar
aps
Originally Posted by DrPJM1
Which Garrett Turbo units are you using?
They are special production turbocharger to APS specs, a GT series Garrett dual ball bearing turbo from Garrett Japan with larger internal wastegate ports, mass air flow is 40 lbs per minute (X 2 for a total of 80 lbs per minute mass air flow) and good for around 800 Horsepower at 16 to 18 PSI turbo pressure.
Peter
Old Mar 23, 2005 | 06:32 PM
  #128
aps's Avatar
aps
Originally Posted by Profile4
hey aps man, in your opinion, wat would be the advantages/disadvantages between the single and twin turbo setup?
The big advantage for the APS single turbo system is the lower up front purchase cost and a much quicker install time.
This APS single turbo system is perfect for guys wanting a super reliable 400 WHP and a practical path to upgrade to around 500 WHP with just the addition of rods and pistons.
By design the APS intercooled single turbo system has far superior power and torque across the entire rpm range than say a centrifugal S/C system (in particular power from 2000 to 4000 rpm is much stronger) and at a very competitive price, the single turbo is a little more expensive than a S/C though it delivers loads more fun factor.
btw, i think i forgot to give you much props on your product. seems like a great kit and has opened up new doors for my FI choice in the future, thanks!
Many thanks and I'm postive that the G35 guys will be in for a fun time over the coming months.
Thanks
Peter
chinee
Jun 10, 2024 07:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Chattzx
Jul 17, 2015 11:23 AM
