Going Greddy TT....recommendations please
Old Mar 23, 2005 | 01:30 PM
Gman2004's Avatar
Going Greddy TT and Rebuilding short block
Ok, I did it. After only 3 weeks of having my vortech installed I decided I want more power.....especially after I got torqued by an STI the other night on the freeway. Please make any recommendations on other items (cheap items) you would suggest I get. When I say cheap I mean little items.
I am planning on building the motor within 6-12 months. I would do it now but the wife would divorce me. She is having a cow about how much money I've spent on the car. For now I plan on running 9lbs. I should have my car back by next friday......I am so fuggin happy!
Here's what I got:
Greddy TT with FMIC
Tial BOV
Greddy Type S boost controller
Greddy Turbo Timers
Greddy EVO II
AAM Spec Fuel Return Solution (bought from Sharif)
Crawford Cast Plenum
Sending ECU for L-spec flash
Old Mar 23, 2005 | 01:57 PM
GXCLUSIV's Avatar
Congrats on the Greddy TT kit. 9lbs boost, around how much rwhp would that get you? Have you considered upgrading the Cam, that way you could run a lower boost to be safe? I say, since your planning on building the motor, probably best to wait on your TT kit install, its the best route and you'll save time and money. 6-12 months is not that long.
Old Mar 23, 2005 | 02:05 PM
Gman2004's Avatar
I should be around 425-435rwhp...I have seen guys with 8lbs around 415rwhp. If I do the cams now that is more labor $$$$...cam installs are really expensive. I am just going to buy a built motor from sgp racing that comes with cams. I will loose less money this way than if I add cams now. I just can't wait 6-12 months.....I want power now!
I plan on getting this motor from SGP.
http://store.yahoo.com/sgpracing-store/sgpravqmo.html
Upgraded Long Block #3: $7500 + $2000 Core
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
*Ceramic coating on Pistons
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*JWT Upgraded Cams
*JWT HD Valve Springs
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Old Mar 23, 2005 | 02:22 PM
GXCLUSIV's Avatar
Was that STI heavily moded? You telling me your vortech could not take him?
Old Mar 23, 2005 | 02:23 PM
Gman2004's Avatar
I have no idea what he had. I am sure he was modded because he came from behind and passed me like I was standing still.
Old Mar 23, 2005 | 02:32 PM
G352NV's Avatar
Never enough
Im sure it was modded, I can tell you my G isnt the fattest car on the road but I know I can take a stock STI. Congrats on the new mods. Only if I had the ***** to go greddy! That 7500 motor is holding me back!
Old Mar 23, 2005 | 02:38 PM
GXCLUSIV's Avatar
Is that $7500 + $2000 core price, mean you send your engine to them for exchange?
Old Mar 23, 2005 | 02:54 PM
Gman2004's Avatar
I know I try not to think about the money......mods so far to day......$22,719 This includes the s/c install/tune and the money I will get back from the s/c sale is already substracted.
Here's what's left on the mod list:
Top Secret Front Bumper $920
Top Secret side skirts $850
Top Secret rear bumper $560
350 evo front arms $850
Spc rear camber arms & toe $220
built motor $7500
Labor $1500
total = $12,400
previous total = $22,719
Final total = $35,119
It hurts to look at that you number.....but you know what? I am so fuggin happy you can't put a price on that sheit. I just keep telling my self I derserve this car.
Old Mar 23, 2005 | 03:02 PM
Gman2004's Avatar
yes
Old Mar 23, 2005 | 03:04 PM
GXCLUSIV's Avatar
Wow thats alot of $ into your hobby. Like they alway say, its best to plan ahead. Probably best if you know your planning on going FI, and 330-370rwhp is not fast enough, then you should plan on getting a TT kit and plan on doing an engine build, before installing the TT kit. Best to do it right the first time. Maybe I should follow this route.
Old Mar 23, 2005 | 03:08 PM
pdjafari's Avatar
Gman, any plans on selling your vortech?!?! man, props to say the vortech isnt enough power!! Good luck on your quest for speed/power, hopefully you'll run into that STI once you have the TT on....
BTW, I noticed you also have a y-pipe and greddy sp2 and you have a 3'' back pipe (mid pipe). I was in the market to purchase the greddy sp2 and already have a Y pipe, but need a 3'' backpipe!! Where did you, or where can I get a 3'' mid/back pipe to fit the 3'' outlet on the Y pipe as well as the inlet on the greddy sp2?!?
Thanks!!
Old Mar 23, 2005 | 03:09 PM
Gman2004's Avatar
Yes definately plan your route first. When I first got the car I was not going to do anything to it.......then all of a sudden I bought a little sound system, then exhaust, then this, then that......I caught a fuggin disease! I will probably will loose around $2000 on the s/c between parts and install labor....not too bad but, it hurts to think about it!!!!!!!!!!
My name is Jorge and I am a mod-a-holic.
Old Mar 23, 2005 | 03:15 PM
GXCLUSIV's Avatar
Originally Posted by Gman2004
Yes definately plan your route first. When I first got the car I was not going to do anything to it.......then all of a sudden I bought a little sound system, then exhaust, then this, then that......I caught a fuggin disease! I probably will loose around $2000 on the s/c between parts and install labor....not too bad but, it hurts to think about it!!!!!!!!!!
Man, your scarring me now, I said the same freak'n thing when I bought my G. Until I got on this forum, thats when I got the disease. Rims, bodykit, exhaust, now going FI. Audio/video is my last project. Definitely contagious. Need to trash my computer, will probably solve my problem.
Old Mar 23, 2005 | 03:18 PM
Gman2004's Avatar
Lately I spend 8-10 hours a day on this freaking board and my350z . I bought a wireless router so I can walked around the house with my laptop.......I take it to the shieter with me!
Old Mar 23, 2005 | 03:19 PM
G352NV's Avatar
Never enough
WERD this forum does not help!
