View Poll Results: FI: What's under the hood?
Twin-Turbo, stock internals.
13.04%
Supercharged, stock internals.
17.39%
Single Turbo, stock internals.
8.70%
Twin-Turbo, 8.5:1 compression pistons.
13.04%
Supercharged, 8.5:1 compression pistons.
0%
Single Turbo, 8.5:1 compression pistons.
0%
4.3L Stroker kit, Normally Aspirated, 11.5:1 Compression.
13.04%
4.3L Stroker kit, Normally Aspirated, 11.0:1 Compression.
8.70%
4.3L Stroker kit, Twin-Turbo, 8.5:1.
21.74%
4.3L Stroker kit, Supercharged, 8.5:1.
4.35%
Voters: 23. You may not vote on this poll
Poll: NA stroker or
Old Apr 26, 2005 | 11:32 PM
mike552's Avatar
This is the email Kyle sent me. Give call a call and tell from Jorge from Carnival sent you. Tel: (281) 444-9195
Will do... thanks again! !PLEASE! pm me once your setup is complete. I would love to hear your input. As for a block, I know a couple of local guys that will eventually get their hands on a VQ block for me at a dirt cheap price. Will all VQ35 short blocks bolt the same? (Disregarding trannies, plates, manifolds, etc.) Are the mounts and head placements the same? If not, is there a cross-reference sheet of S/N's anyone's aware of?
Old Apr 26, 2005 | 11:35 PM
Gman2004's Avatar
No problem....I will keep everyone posted on the progress.
As far as any VQ35 fitting with no problems, I don't see why not. Ask Kyle you will know for sure.
Where are you located BTW?
Old Apr 27, 2005 | 12:19 PM
mike552's Avatar
Boston, dude. Too bad. But keep us updated anyway.
Have you thought of boreing out the head? Is that even feasable on the VQ? How about the valves, I hope there are bigger intake valves available.
So many questions.....
Old Apr 27, 2005 | 12:23 PM
Gman2004's Avatar
Yeah I was going to go with this package but I started thinking about it and it is just overkill. This set up should be good for 600+rwhp. At that point you would have to ugrade the axles. Anthing over 500rwhp you gonna have trouble with traction so I decided just to do the short block and no head work.
Upgraded Long Block #3: $7500
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
*Ceramic coating on Pistons
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*JWT Upgraded Cams
*JWT HD Valve Springs
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Hal@IP
Intake & Exhaust
97
Sep 29, 2011 05:14 PM
XKR
Forced Induction
203
Jun 5, 2011 11:59 PM
ynhrgt
26
Nov 22, 2005 03:17 PM
gumpdriver
Oct 30, 2004 01:30 AM
exagorazo
Forced Induction
27
Sep 12, 2004 11:14 AM
