New parts in preparation for my built motor
Old May 23, 2005 | 09:03 PM
Gman2004's Avatar
Just wanted give an update and show everyone my new parts. I should get my motor back in the next 2-3 weeks. Allowing for delays, I would say I should get my car back by the end of June.
Attached Thumbnails New parts in preparation for my built motor-aps-oil-pan.jpg   New parts in preparation for my built motor-s.jpg   New parts in preparation for my built motor-koyo-radiator.jpg
Old May 23, 2005 | 09:07 PM
Gman2004's Avatar
I will go ahead and post some more pictures I took while I was bored this weekend. I am going to put a defi d fuel pressure gauge in the empty hole. I should have it by the end of this week.
Attached Thumbnails New parts in preparation for my built motor-gauges.jpg   New parts in preparation for my built motor-boost-timer.jpg   New parts in preparation for my built motor-engine-bay.jpg
Old May 23, 2005 | 09:14 PM
Gman2004's Avatar
two more....
Attached Thumbnails New parts in preparation for my built motor-car-shot.jpg   New parts in preparation for my built motor-dish.jpg
Old May 23, 2005 | 11:25 PM
GZire's Avatar
Looking good.
Where did you buy the A-pillar (does it clear the air bags) & gauges from?
Old May 23, 2005 | 11:27 PM
Gman2004's Avatar
I bought them from intensepower.com. Best prices I have found on those particular items. The color for the tan pod matches perfect too. What do you mean about the air bags?
Old May 24, 2005 | 12:25 PM
lucidazn's Avatar
What is the difference between the long block andthe short block?
Old May 24, 2005 | 12:34 PM
Gman2004's Avatar
The short block is the bottom end.....rods and pistons. The long block refer to the whole motor with head work.
Old May 24, 2005 | 12:44 PM
TINMAN's Avatar
Koyo made radiator for G35??? last time i check,they only have it for 350Z not G
Old May 24, 2005 | 12:46 PM
Gman2004's Avatar
The mounting brackets have to be extended. Any shop that has experience fabricating can do this.
Old May 24, 2005 | 09:00 PM
TeinG35's Avatar
Gman, could you explain a little more, i would like to get a koyo rad. in my car and iam in miami .... what shop can do this 4 me?? thanks btw cant wait to see your car run its gonna be insane
-Gabriel
Old May 25, 2005 | 10:39 AM
Gman2004's Avatar
I don't know how to explain it cause I am no mechanic. When I bought the Koyo from GSC motorsports the guy told me that the brackets has to be extended. He told me it can be done if I have a shop that has experience fabricating. I am getting my work done at South Florida Performance. PM me your number and when they start putting my car back together I will give you a call so you can check it out. It should be another 2-3weeks.
Jorge
Old May 28, 2005 | 12:04 AM
GZire's Avatar
Sorry Gman2004, I lost track of this thread.
I was concerned about the side curtain air bags. It looks like the bags will clear the pod, I just don't know what the wires(?) are that run down the A pillar.
http://img285.echo.cx/img285/299/dsc001196do.jpg
Old May 30, 2005 | 08:37 PM
yeahi's Avatar
are u going to be using 550cc injectors? high or low? I see you have a fuel pump, but do u have a fuel pressure regulator?
Old May 30, 2005 | 09:51 PM
Gman2004's Avatar
Yeah, I am going to use the 550's. My new motor will be good for 600+whp but that is just to damn much power. With the 550's I might be able to get to 570whp or so on my high boost setting. That is good enough for me. I don't know if they are high or low....what ever the VQ uses. You can't choose with the G (that's what I was told). The fuel pressure regulator came with the AAM fuel return solution.
Old May 30, 2005 | 10:28 PM
yeahi's Avatar
oh ok, not too familiar with the G, i am going to run a fpr but never heard of a AAM fuel return solution with the fpr, that's prob. cause i'm not too familiar with VQ motors, just the K series. But, with the FPR and the fuel return, you should be running around 550 or so whp before the duty cycle is maxed out. Damn...that's going to be a sick *** G man! congrats and good luck!
