Vortech Finally Tuned
Old Oct 29, 2005 | 11:42 PM
  #31
Dan_K's Avatar
Vortech Question: Can you guys feel a difference in tq under 3500 rpms? Or is it very similar to stock? Because I do most my driving under 3500 and I don't want to be flooring it everytime just to feel the power. Would the TN ST kit be a better choice for a flat torque curve?
Old Oct 30, 2005 | 01:05 AM
  #32
G2FAST's Avatar
+1 can someone answer this please.......
Old Oct 30, 2005 | 08:19 AM
  #33
Julian's Avatar
If your driving habbits are that conservative then the addition of a SC would be pointless.The SC builds peak boost at redline.To feel peak TQ and HP at 4000rpms you need TT's
Old Oct 30, 2005 | 11:08 PM
  #34
Dan_K's Avatar
Well, I don't want to feel peak tq under 4k, since I will be losing traction everywhere if I were to floor it. I just want to feel a power difference under 4k. Something that pins you back in your seat or maybe even a little. Will the Vortech do this?
Old Oct 31, 2005 | 06:53 AM
  #35
neffster's Avatar
1. You won't "lose traction" if you don't go WOT. You won't need to go WOT with all of that extra 'giddy up'.
2. The CF-S/C is 100% linear. You won't "lose traction" unless you're WOT with stock tires. You can easily go 3/4 WOT and not lose traction and keep VDC on if you like.
3. Odds are that if you get a S/C or a turbo of any type, that you will be going WOT much more than you'd ever think.
4. Do everything you can to get in someone's car that has a S/C or a turbo, take a ride along and see what all the fuss is about.
Old Oct 31, 2005 | 06:57 AM
  #36
Dan_K's Avatar
neff - how is the hp/tq increase under 4k? could you tell me your impressions? thanks.
Old Oct 31, 2005 | 08:47 AM
  #37
Brando's Avatar
I'd say virtually no change under 3500 rpms....feels like stock cause you aren't building any boost.
Old Oct 31, 2005 | 09:25 AM
  #38
neffster's Avatar
I'd say you are building boost... and there is definitely a difference IMO. First off, you don't drive around at 600-1000 rpms very often so forget about the very very low end of the scale. Secondly, since you're usually driving around somewhere in the 2500 rpm range, you're making boost as soon as you give the car enough gas to raise the fuel pressure. Granted it's only around 2 to 3 psi of boost, but that's a far cry from running at vacuum like a NA car.
At 2500 rpm you're spinning the blower and generating between 15,000 to 20,000 cfm and that is going to make a nice difference over a NA G35 IMO. This is why driving in a stock G every now and again is a good thing. 2 days ago I was in SFLG35's car which is a non FI (modified) 5AT Coupe and I could tell a noticable difference as soon as he gave it gas. It just seemed to be missing that little kick in the rear end feeling of the S/C down low.
IMO, it makes more of a difference down low than all of the NA mods I used to have (then again I now have all of the NA mods and the S/C so take this comment with a grain of salt...)
As always, YMMV! Still love ya' Terry!
Old Oct 31, 2005 | 10:06 AM
  #39
g8tor20's Avatar
FGC's official flip flopper
I may be spoiled. I have to drive a NA car for a few days.
Whats getting annoying is the squirly 1st and 2nd gear. I was crusing today at like 25mph in regular Auto mode and I hit the gas. I felt her drop gear, I guess 3rd to 2nd) and as soon as I hit like 5000 rpm, I felt her back end start to slip. And first gear is just a joke as it gets squirly every time past about 4500rpms and the RPMs reach 7000 in a milisecond. I guess thats the drawback for having a granny tranny, right Neff? haha
Old Oct 31, 2005 | 10:07 AM
  #40
g8tor20's Avatar
And yes....I do apologize for this attempted hi-jacking of the thread.
Old Oct 31, 2005 | 10:47 AM
  #41
neffster's Avatar
2 words... throttle modulation.
Old Oct 31, 2005 | 03:44 PM
  #42
Brando's Avatar
Humm Neff.....a totally different observation than mine.
I really see or feel no difference under about 3200-3500 rpm maybe partly cause my car was very fast reving before when I had the UR crank pulley.
or Maybe my car is a FREAK.......
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
9tray turbo
Sep 29, 2015 10:22 PM
