Vortech vs APS ST vs Turbonetics
Old Oct 30, 2005 | 10:52 PM
G-Mann's Avatar
wait, are u guys saying that the Turbonetics kit isnt a complete kit that you need something like the e-manage? or would i be safe runnin just the turbonetics kit?
Old Oct 30, 2005 | 10:55 PM
imalazeeass's Avatar
it is safe running by itself. However, you can get the tuner kit w/ the emanage if u want to.
Old Oct 30, 2005 | 10:56 PM
PhxBlue's Avatar
Polyester Pileup FTW!
The T-netics is good to go outta the box if you drive an 03 or 04 you just have to send them your ecu. They dont have a reflash done yet for the 05 revup motor in which case the 05'ers are getting emanage ultimates to bypass that problem.
Old Oct 31, 2005 | 12:50 AM
G-Mann's Avatar
i c. so what 1/4mi times do you guys think would be faster, the APS, or the Turbonetics? or the vortech for that matter?
Old Oct 31, 2005 | 12:57 AM
G2FAST's Avatar
Originally Posted by TINMAN
still questioning about FI huh Josh? for the past year you haven't make up your mind yet?
No not yet, more kits out now than last year and more homework to do.
Old Oct 31, 2005 | 10:59 AM
jaspergtr's Avatar
what kind of exhaust temps should we expect to see in the tn kit?
will they be considerably higher than the vortech?
Old Oct 31, 2005 | 02:00 PM
MIAPLAYA's Avatar
My EGTs run around 600-800 while cruising....highest EGT I have seen under ful boost and WOT was 1100.
Old Oct 31, 2005 | 02:01 PM
MIAPLAYA's Avatar
There are several versions of the G kit being released:
6MT no cat
6MT w/ cat
6MT Tuner
5AT no cat
5AT w/ cat
5AT tuner
The tuner versions come with no flash, fuel pump, or injectors so you can get your own and use your own management if you want. All other version come with a Walbro 255 lph fuel pump, 380cc drop in plug injectors, and a reflash.
Old Oct 31, 2005 | 02:03 PM
MIAPLAYA's Avatar
I havent seen any 1/4 mile times for the APS ST kit yet but I know most of the times I have seen for the Turbonetics kit cars are 12.4-12.7 @ 110-115 MPH on street tires (usually 19")
Meatshackle's Avatar
Deep Sea Moderator
Wow, that's a lot of versions. I have no idea which one I'm getting.
I didn't have all of those options when I ordered.
Old Oct 31, 2005 | 02:16 PM
MIAPLAYA's Avatar
Unless you specified otherwise and you have a 6MT G35 you are getting the 6Mt kit with no cat. If you do want the cat I think you can buy the downpipe with the cat seperate and that would make it interchangeable if you want...
Old Oct 31, 2005 | 06:17 PM
G2FAST's Avatar
I've heard that APS is more tuner friendly than T-netics, is this true or will this change when T-netics comes out with the tuner kit?
Old Oct 31, 2005 | 07:47 PM
MIAPLAYA's Avatar
I'm not sure where you heard that. APS is no more tuner friendly then the Turbonetics kit. The APS uses a unichip which can only be tuned at 3-4 select tuners in the US.
Old Oct 31, 2005 | 09:05 PM
bullitproof's Avatar
japtrix, xxtuning, altered atmosphere- all on the east coast and tune unichip. there's still chicago, texas, and cali that does unchip. i think what the guy wanted to know is the aps kit has a tunable unihip piggyback. the t-netics kit has a reflashed ecu unless you order the t-netics tuner kit- then you buy your own piggyback setup or ems. just the facts homie.
Old Oct 31, 2005 | 09:22 PM
  #30
MIAPLAYA's Avatar
Or you can buy and Emanage Ultimate for $595 and add it to the already better out of box tune on the Turbonetics kit and Still be $800 cheaper then the APS kit and get better power when the EU is tuned.
