Vortech vs APS ST vs Turbonetics
Old Nov 3, 2005 | 08:23 AM
  #46
Brando's Avatar
Cool
Same here......
If I was going to build the motor, I'd go Turbo.
If I wanted over 450HP, I'd go Turbo. (Actually, I'd just buy a faster car to begin with)
High Torque at lower RPM is what breaks things.
I am very happy with my Vortech.
The only downside I see to the SC at all.......is the noise.
Old Nov 3, 2005 | 12:09 PM
  #47
BlkG35FujiCoupe's Avatar
So where would the best place be to get a G35 Turbonetics kit?
Old Nov 3, 2005 | 12:39 PM
  #48
jnkirk1974's Avatar
Fastest G35 In Rockwall
I'm a little curious about this kit. Why is it that you DON'T have to tune your car for it? I thought you needed to tune, regardless of what type of FI kit you went with........
I'm no expert though. Can someone explain this kit a little more?
Old Nov 4, 2005 | 01:23 AM
  #49
MIAPLAYA's Avatar
The Turbonetics kit includes a reflash of the ECU byTurbonetics using a map that they developed. For almost every car the map has been dead on. Its extremely safe but makes the most out of box.
Old Nov 9, 2005 | 05:22 PM
  #50
beangrower's Avatar
and this flash is for everything else stock. ie...stock exhaust, cat, pipes....?? if so, what if you upgrade? would you have to reflash? i'm torn between the vortech and turbo st kit.
Old Nov 9, 2005 | 05:45 PM
  #51
MIAPLAYA's Avatar
No you dont have to reflash. The ECU still uses the MAF to adjust fuel and timing within a range just the timing values are made safe no matter what...plenums, exhausts, will not change this.
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
g.spot
May 9, 2016 10:54 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
n2fooz
Sep 4, 2015 07:46 PM
