Its starting to come together :)
How much boost can you run with that set-up. There website say 402rwhp @ 6.5psi. Can you run upwards of 18-24psi? I would like to get a TT kit, but feel they are kinda useless spending all that money to run under 10psi. I bet you would see really nice numbers like 600rwhp @ 18-22psi and that is where I wanna be.
Kit looks nice by the way.
The 402bhp at 6.5psi was with the older version of this kit which also used smaller T3 turbos.
I should see 500+bhp at 10psi with this kit(T60-1 hifi turbos) and my engine setup.
What kind of front control camber arms you have there?
Also, are you getting any "loose" noises from the rear of your HKS RS coilovers? I am and it's pissing me off. It only happens when I go over bumps.
Only two parts left that need to come in. The one holding me back is the Cosworth Headgasket and later on my PE radiator will get here that we have to modify to fit.
Tims fab job is amazing on those manifolds. I wish he would make equal lengths for the ST guys..Nice stuff there. Turbos are looking VERY pretty
I can't wait to see your car finished. What cams did you order and from where?
There arnt any cams on the market that will fit the rev-up heads, and a custom grind cant be made yet either so im just using the stock ones for now.
Here is more of his work
magnetism80
Feb 1, 2019 10:00 AM
Rhinos7777
Sep 6, 2015 05:36 PM
