Hear and see a stillen stage 2 g "VID"
Old Nov 13, 2005 | 11:24 PM
Toptoneone's Avatar
Originally Posted by arjunz
Your car sounds soooo sweeet....
Thank you
Old Nov 13, 2005 | 11:33 PM
my_Gthang's Avatar
nice...sounds good...
Old Nov 14, 2005 | 12:30 AM
booger's Avatar
any one else having trouble with video's loading up on Streetfire ? I click on the link in this thread and others, and it goes to the page but it never loads . It doesnt even show the normal black box where the video would play
Old Nov 14, 2005 | 12:31 AM
Toptoneone's Avatar
works ok for me. Ill post again on a different sight,
Old Nov 14, 2005 | 03:50 AM
bfan13's Avatar
were you running on slicks?? I have so much trouble hooking up with the stillen =[[
Old Nov 14, 2005 | 10:11 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
nice vids...I've ran there too and the best i could pull off with my 19's was a 13.4...here's a pic of me staging there...aawww, CalSpdWay! I love it.
BTW, what were your 60' times like? I couldn't get better than a 2.22
**sorry, saw your 60' time in your first post...DAMN, you had to be running slicks, no? If not, what type of tires and at what pressure.
Old Nov 14, 2005 | 01:59 PM
Toptoneone's Avatar
I was running bfg drag radials on my stock 18's, really helped. On my street tires I couldn't launch above Idle on my tach. I was launching at 2000 in the slower video and 3000 on the one where I race the civic. I ran the tires at 18 psi. I was told to run them at 15. I was also told to launch at 5000. I want to ease into it. on dec 3rd I'm going again and Ill try a little more aggressive.
Old Nov 14, 2005 | 02:00 PM
Toptoneone's Avatar
my 60' times were 2.020 and 2.065. I had a run that day where I did a 2.65 when I had the tires at 32 psi. bfg drag radials
Old Nov 14, 2005 | 02:09 PM
a.k.a. RANDYS_G
cool...look forward to your Dec 3rd posts...have fun and be safe bro...btw, if you speed shift, you'll knock a tenth or two off your time...that's when you keep the accel down between shifts...just don't miss the shifts...otherwise known as "don't lift to shift!"...I did that at a track out here and knocked two tenths off of my best time of the night.
Old Nov 14, 2005 | 02:20 PM
Toptoneone's Avatar
I was lifting when I shifted. I think it would be better to hold the pedal down because you dont lose boost that way. But when I tried it went into redline. So I need to practice a little when to shift. Thanks for the advice, its always helpful when people pass info on.
Old Nov 14, 2005 | 02:23 PM
Toptoneone's Avatar
did you notice when I was up against the mustang I tried to hit the brake and get a hotter and longer burn out. It didn't work to well, the car just lost power. I think nissan made the car so you can't do that.
Old Nov 14, 2005 | 02:39 PM
Toptoneone's Avatar
http://media.putfile.com/1344-g35-stillen
http://media.putfile.com/1352-g35-stillen
try this.
Old Nov 14, 2005 | 02:45 PM
Toptoneone's Avatar
When you ran your 13.4 what was your trap speed?
Old Nov 14, 2005 | 08:59 PM
Toptoneone's Avatar
How does one do one of those long burn outs?
Old Nov 14, 2005 | 09:50 PM
  #30
Dsskyline's Avatar
I had a decent run I was pretty happy. Still want more but for know I'm content. This is a lot faster than the 14.7's I was running stock at the same track. I love kill'n those dern honda's.
Based on:
Temp: 85°
Humidity: 58%
Track Altitude: 1120 feet
Pressure: 30.19 in.
Density Altitude = 3035 feet ET MPH
Uncorrected 13.44 @ 104.57
Corrected 12.96 @ 108.32
My 60' was 2.020
http://videos.streetfire.net/player....5-851858564A87
Hey what did you do or use to get your corrected times? I raced at Cali Speedway in August and ran a 14.43 @98 N/A. I could of done better if I brake torqued. What size DR's do you have? I have 245/40 18 on my stock G wheels since I thought the 265 would be too wide for the wheel. Good luck on the 3rd. Anyone know the air density altitude for LACR? The best I can do there is a 14.8-15.2.
