Hear and see a stillen stage 2 g "VID"
Old Nov 19, 2005 | 08:01 PM
  #46
Toptoneone's Avatar
Originally Posted by GurgenPB
Are you sure tat's it's the density altitude that's used for correction? DA is used, from what I know, to adjust for effective airfoil efficiency/performance (airpane propellers, wings) given pressure altitude and temperature. The temperature correction that goes into calculating DA is not as relevant for true air density calculations, and is a measure of what the performance (if it had applied to interal combustion engines) would have been not at 85 degF at sea level, but at 59 deg F (15 deg C) at sea level. Also, know that the altitude/elevation corrections do not apply to FI cars the same way they apply to NA cars; pressure/efficiency is regained by FI at elevations. Also, was it 30.19" ambient, ot was it the altimeter setting? The reason I say this is if itwere the latter (which is wha't ost often reported in the area), then it can actually help your numbers, not hurt them.
The car sounds very nice, and pulls nicely as well!!! I am not trying to rain on your parade, only to point out what the accurate number are more likely to me IMO (I may be wrong, of course). I just think that your car, especially with the very nice launch, pulled pretty much as advertised. I just don't think that there is a 0.5 second correction is 1000' of altitude. However, if it were cooler (59degF) at sea level as well, the car would much more likely to get that ET.
I pulled it off of weatherchannel.com. ask them
Old Dec 5, 2005 | 05:46 AM
  #47
luongdmd's Avatar
the sound of the stillen is intoxicating
Old Dec 5, 2005 | 12:55 PM
  #48
Toptoneone's Avatar
Thanks. I ran a 13.3 adjusted would be a 12.8 on this saturday. I ran a 1.9 60 ft. That stillen is a torque monster off the line. I just wish it had all the top end power that it does off the line.
Old Dec 5, 2005 | 01:08 PM
  #49
ratedxmarcel's Avatar
^should of went with a big single turbo then :P or more boost...what is the max psi on the stillen stage 3
Old Dec 5, 2005 | 01:58 PM
  #50
Toptoneone's Avatar
7 psi. I cant and wouldn't put a turbo on my car till carb approval.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
Jeff T
Sep 30, 2015 02:00 PM
