Can someone provide me a list of Turbo kits?
Old Nov 15, 2005 | 04:48 AM
ynhrgt's Avatar
I'm trying to decide between all the turbo companies out there that make kits for the VQ35De. Could someone provide a list of companies that make Twin-Turbo kits?
I have already looked at kits from Greddy, Turbonetics, etc.. and I wasn't too impressed by the numbers. 140 HP gains from the Greddy kit doesn't impress me at all. I'm looking more for quality and potential to make horsepower, as I guess most people are.
I've heard JWT makes a kit too, I'll go check them out right now.
Feel free to let me know about any smaller companies doing TT kits as well, Thanks.
Old Nov 15, 2005 | 06:46 AM
neffster's Avatar
Greddy
Turbonetix ST
APS ST/TT
SFR TT
JWT TT
are the ones that immediately come to mind.
Old Nov 15, 2005 | 08:06 AM
Meatshackle's Avatar
Deep Sea Moderator
So a 60% gain in hp on stock internals on a non-fi car doesn't impress you? You might want to buy a subaru.
Old Nov 15, 2005 | 08:48 AM
Dieselnuts's Avatar
agreed, 140hp is respectable for any bolt on anything imo.
Old Nov 15, 2005 | 09:15 AM
DaveO's Avatar
Shameless plug...
Attached Thumbnails Can someone provide me a list of Turbo kits?-szm-19-summer-05-cover-m.jpg
Old Nov 15, 2005 | 08:30 PM
neffster's Avatar
Sorry, I forgot PE - TT.
Old Nov 15, 2005 | 09:31 PM
ynhrgt's Avatar
I know this is probably a very vague question..
Which kit has the most potential?
Old Nov 15, 2005 | 10:33 PM
GXCLUSIV's Avatar
The SFR 60-1 hifi TT kit is capable of 1000rwhp. You will need to upgrade your injectors and fuel system and of coarse build-up your motor. You could also put this kit on a completely stock car and build your motor,heads,fuel system down the road. No need to upgrade your turbo or wastegates. On stock Z at 8.5psi on 91 oct. it dynoed 439rwhp and 449ft/lbs of torque, on stock exhaust, and plenum. Was told on stock G35 you might get an extra 15-20 ponies.
Old Nov 16, 2005 | 01:00 AM
SI_G35Coupe's Avatar
why would the G35 have an extra 15-20 ponies on an otherwise identical motor... is it because of the dual intercooler setup on the G35 system?
Old Nov 16, 2005 | 01:08 AM
GXCLUSIV's Avatar
From what I was told by Tim at SFR, dyno # results are higher on G35's. Not sure why, give Tim at SFR a call.
Old Nov 16, 2005 | 02:35 PM
bsp's Avatar
bsp
It sounds like you're looking for APS perhaps? Let me know if you have any questions/concerns regarding their system. We are their major west coast distributor and we'd be more than willing to help you out.
Old Nov 16, 2005 | 11:12 PM
damen's Avatar
Eternal Motorsports is a new company that's coming out with a single turbo kit sometime early next year, that i have on my car now. my car was used for test fitting and tuning. i'm running 383hp and 416tq at 9psi.
Old Nov 17, 2005 | 06:42 AM
Dsskyline's Avatar
How is the car holding up? Have any good or bad impressions about the kit? I'm getting the same kit in a couple of months. Here is what's included if anyone is interested they are having a special on the kit right now. PM me if you want to know the original and special price.
*Designed for 2003 –Up Infiniti G35 and M35. *Bolts directly on to the stock VQ 3.5 L engine. *No additional modifications.*
*Uses stock manifolds, cutting down on installation time. *Garrett GT35-R duel ball bearing water cooled turbo and includes:
*External TiAl 44mm waste-gate. *3” down pipe that connects to a high flow catalytic converter that mounts to stock muffler.
*Stainless steel heat shield. *440cc fuel injectors. *Fuel pressure regulator and Walbro High Flow Fuel Pump with fuel return.
*Air to air intercooler. *Ceramic Heat Coated Stainless Steel piping (available in polished look, flat black, or red finishes).
*All required hardware and installation manual is included. *Stainless steel braided Teflon water and oil hoses.
*Pre-programmed piggy-back UniChip fuel management that interfaces with stock ECU.
*Performance from stock 3.5 L engine at 8.94psi is 383whp and 415 ft lbs torque.
*Smog compliant in most states with standard boost. Check your local laws prior to purchase.
*Boost Capabilities up to 25 PSI with internal engine modifications.
*Some A/C lines are replaced and or relocated. Everything needed for installation is included in the kit.
Old Nov 17, 2005 | 09:06 AM
Mario77746's Avatar
I thought a 60-1 was only good for 650-700hp / 550-595rwhp max?
Old Nov 17, 2005 | 11:43 AM
djniknala's Avatar
They're using 2 of them.
