vortech installed, now what?
Old Nov 27, 2005 | 12:29 PM
  #31
jaspergtr's Avatar
gear backlash? can someone explain the rattling? i mean, when you hear rattling, in a component like this, metal is most likely hitting metal. that doesn't sound good.
Old Nov 27, 2005 | 03:27 PM
  #32
jsal's Avatar
Here's a technical definition...
Gear Backlash: Properly functioning mechanical systems need to have a certain “clearance” (“gap”, “play”) between the components transmitting motion under load. Clearance is necessary to avoid interference, wear, and excessive heat generation, ensure proper lubrication, compensate for manufacturing tolerances etc. Clearance in the gear mesh means that the gap between the teeth of one gear is by a small amount larger than the tooth width of the mating gear.
We also find a certain clearance in the rolling bearings, namely a small clearance between the inner race, rolling body (ball, roller) and outer race of the bearing.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
gatorglaze
Sep 10, 2015 12:03 PM
n2fooz
Sep 4, 2015 07:46 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
