are these the parts i need for safe turbo?
Old Jan 12, 2006 | 12:34 AM
v35gt's Avatar
I have an 05 DG AT coupe going Greddy TT.I was at my friends shop today and they told me that i need these parts to run a safe turbo for my car. Juss for the time being until i go high HP. =]
-Torque Converter
-Straight Pipe, test pipe
-AAM fuel return system
-BOV
-Turbo Time
-Boost Controller
-Boost Gauge
-Oil pressure gauge
Am i missing anything or anything i dont need? If i am please let me know because i dont want to buy some parts that is useless like my AEM CAI. Thanks
Old Jan 12, 2006 | 01:14 AM
hyperlitesmu's Avatar
2 Cars......2 Turbos...
Tank goodness you included a fuel return!!!! That shop just went up a few points. If you want to get kinda crazy you could throw in a low compression head gasket set to get the compression down to 9 or 9.5 to 1. Or as an additional safegaurd you go for an Aquamist 1s and spray some methonal in the intake to seriously beef up your intake charge. Another good/cheap mod is a motordyne intake spacer w/ iso thermal kit.
Old Jan 12, 2006 | 01:21 AM
v35gt's Avatar
i already have a skunk2 spacer so its all good =] but u said get a low compression head gasket how much would that cost?
Old Jan 12, 2006 | 01:28 AM
Dependa on the shop. The gasket will set you back $200 or so depending on what the shop can hook you up with......the problem is ging to be installayion. That takes a number of hours and will make the whole mod cost just under $900 or so depending on the labor rates the shop charges.
Old Jan 12, 2006 | 01:41 AM
v35gt's Avatar
do you know any sites where i can check up on the prices for all the parts i need? thanks
Old Jan 12, 2006 | 09:59 AM
Not sure what the official Aquamist site is but if you do a Google search for "Aquamist" you'll be in good shape. As for the Gasket.....I'm pretty sure Greddy makes one. A great source for parts is Projectnissan.com
Old Jan 12, 2006 | 01:11 PM
v35gt's Avatar
alrite thanks alot
Old Jan 12, 2006 | 05:05 PM
GZire's Avatar
I'd look into a good air/fuel ratio (AFR) guage too at the very least and maybe an exhaust gas temp (EGT) gauge.
Old Jan 12, 2006 | 11:30 PM
meatbag's Avatar
I dont think anyone makes a thick enough gasket for our motors to lower compression. To intstall the headgasket you motor will need to be taken out as the head studs prevent the heads from being removed in the engine bay. Might as well just keep a safe tune and not run alot of boost untill you are going to rebuild the motor. You forgot the thing thats going to make the biggest difference; the timing harness if you are sticking with the emanage blue. You might want to make sure you get the FMIC for the greddy kit as it is not standard either. To go with your return fuel system youll want to get injectors otherwise its not worth getting the AAM return fuel system in the first place.
hdmark
Apr 29, 2019 04:31 PM
LuisGee
Forced Induction
13
Jul 22, 2015 09:15 PM
Chattzx
Jul 17, 2015 11:23 AM
