HKS Supercharged G
Old Feb 7, 2006 | 01:33 PM
  #46
ScottR's Avatar
^ pardon my ignorance...so you’re saying that the torque at sudden peak couldn't cause engine damage? I have a tuner next door to my shop that blamed his rod coming thru his engine case (on a ST miata w/stock internals) on the sudden torque. Again, I don't even pretend to understand how the turbo set ups work but that did make sence to me. But obviously judging by post upon post the tune is absolutely critical as well. Care to elaborate?
Old Feb 7, 2006 | 04:11 PM
  #47
BrianlG35C's Avatar
Ohio G Club Member
What I'm saying is...The history of VQ engines blowing on twin turbos are mostly (if not all) related to faulty installation and tune, not sudden torque. Do a search on all the history blown engines over on my350z and you'll see almost all are Greddy, self installed and not tuned properly. Then there's the notorious crank angle sensor wire problem as well that's also assumed to cause many of the blown Greddy TT cars.
Old Feb 7, 2006 | 04:29 PM
  #48
ScottR's Avatar
Interesting...thanks bro.
Old Feb 7, 2006 | 07:11 PM
  #49
tig488's Avatar
there are a handful over at my350z running over 500whp and tq still on stock internals. id be scared if that was my car, but i guess if you trust the tune, thats good enough.
Old Feb 7, 2006 | 09:45 PM
  #50
booger's Avatar
Any idea what caused the ringland break? I have heard of some of the other SC guys mentioning this.
I had tuned the car with less timing [ 15 degree advance after 6000rpm ] While at the track , temps had cooled 30 degree's from earlier , at the end of a run . I believe the stock ECU put back 2 to 4 degree's of timing back in . Which caused detonation and broke off a chunk of the piston and it got lodged in the exhaust valve . This was on stock compression and
9.2psi of boost
Old Feb 7, 2006 | 10:26 PM
  #51
ScottR's Avatar
Sounds ugly, next question, is there anything that can be done to avoid this from happening? Was there another fuel/timing mgt, system in place or just running off of the stock ECU with maybe a re-flash? I am running the F-con SZ but could this sort of thing still happen given the temp. changes etc?
Old Feb 7, 2006 | 10:47 PM
  #52
booger's Avatar
Vortech has a piggyback ECU . Timing and fuel control . But it cant control what the stock ECU from adding timing back in . The only way to avoid it is to have the stock ECU flashed to get rid of the aggresive timing map [ I believe ] . Or go with the TurboX Utec .
Old Feb 8, 2006 | 09:15 AM
  #53
ScottR's Avatar
That's good to know. AAM did a ECU Flash as part of my tune, so hopefully this won't be a problem down the road.
Old Feb 8, 2006 | 11:32 AM
  #54
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Originally Posted by BrianlG35C
Wrong!! It's the tune not the torque!
True. But torque does break things...
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
