APS Single Turbo Grinding
Old Feb 19, 2006 | 08:02 PM
klg35's Avatar
Originally Posted by Ant830
the single is deff. cheaper but doesn't have the hp capability of the TT unless you go with a larger turbo but then you lose low end tq. because it takes longer for the turbo to spool.....unless you spraying before full boost...but for the most part....TT = faster spool up = more tq. down low and more hp out of the stock turbo's. But the aps or turbonetics put down more power than my greddy at stock boost. There's a lot more to it but that's the basics.
ok, what are your thoughts on the turbonetics single? probably not as much hp on top?
g.spot
May 9, 2016 10:54 PM
Learned Hand
Oct 1, 2015 09:02 AM
9tray turbo
Sep 29, 2015 10:22 PM
alinero718
Sep 27, 2015 09:35 PM
