Water Injection
Old Feb 23, 2006 | 08:42 AM
3.5T's Avatar
Water Injection
Would water injection be overkill with the Turbonetics S/T kit being run on their ECU reflash? Would it wrok properly with their ECU reflash or do you need the ability to tune?
Old Feb 23, 2006 | 10:54 AM
djniknala's Avatar
You would actually lose power if you just put the WI on. If you were to retune and run more timing(which the WI will let you do) then you could get more power out of it. You can also run much leaner without knocking. You could just up the boost a few psi with the WI and you would effectively be running more timing and leaner. Doesn't sound like a bad idea and a good way to turn $500-$1000 into 50whp+.
Old Feb 23, 2006 | 11:41 AM
3.5T's Avatar
I going to run the stock set-up for awhile (till funds recover) but I was thinking down the road of what I could do to up things.
Mad A
DFW Classifieds
Mar 28, 2016 11:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
