Up and running Woooo Hooooo!
Old Mar 11, 2006 | 08:41 PM
BeerViper's Avatar
Wow, do you really think it's the new IC setup that is allowing you that much boost or just the T-trim blower? You are also running the 3.12 pulley correct?
I also like the front bumper ... which one is that?
Old Mar 11, 2006 | 09:03 PM
booger's Avatar
Thanks....Its the Kumura bumper . Yes Im sure it was
Old Mar 11, 2006 | 10:41 PM
blksnake's Avatar
Your Kumura bumper looks very nice! Post some more pics please!
Old Mar 11, 2006 | 10:55 PM
booger's Avatar
I had the T-trim on with the smaller IC and the belt would slip at 13psi . The preasure build up between the blower and the IC was to much and the belt slipped . Old numbers and new
old.......new
3500rpm..4psi.....4.5
4000.......4.8....5.5
4500.......6......7
5000......8.......9.2
5500.......9.5......11
6000......11.5 ?
I never went passed 5700rpm's today and boost was at 12psi
The bigger IC allows the blower to breath much better and boost preasure build up between blower and IC isnt as much
Old Mar 11, 2006 | 11:25 PM
BeerViper's Avatar
Sounds like I may need to look into a different IC setup, looks like untapped HP just waiting to be unleashed! I thought I saw you post in another thread what FMIC setup you went with but don't remember ... what was it you ended up going with? Also I can't remember if you are running the 3.12 pulley or not. I know I can't go as aggressive as your setup since you're built and I am on stock internals with stock fuel injectors but I can still go up a little!
Also have you tried contacting Split Second about what happens above 16psi? You can submit an information request on their website... http://www.splitsec.com/
Old Mar 11, 2006 | 11:30 PM
booger's Avatar
yah..I emailed them 2 weeks ago about it ...no reply ...I'll have to call them.
I think if you try to go passed 9-10psi . A bigger IC will help flow more air . I went with a IceVex IC. 12+4+31 . I also went to 3 inch pipe from the IC to the TB , which also helped with flow
Old Mar 12, 2006 | 01:45 AM
urban's Avatar
The website which lists the larger IC actually lists the core size which is 12+4+24 but it is still the same IC.
I had to look twice before I found it myself.
Old Mar 12, 2006 | 09:46 AM
booger's Avatar
If you go to MeanGenes thread over at My350.com call { I pulled the trigger ] Rabbid posted a pic with both stock IC and the IceVex side by side , to compare them to each other
Old Mar 12, 2006 | 10:45 AM
MeanGene's Avatar
Smile FMIC Pics
http://www.my350z.com/forum/showthre...=176943&page=2
MG
Old Mar 12, 2006 | 10:46 AM
MeanGene's Avatar
Smile Project Foundation
Gang - I've been bombarded with PM's about my current project from folks wanting to know the parts & details. First all, thanks to everyone for their interest & support ( even the expected "why not go turbo?" questions ). Here's a recap of all my parts - most from Sharif @ Forged Internals ( GREAT vendor & person in general )
AEBS block bored & sleeved to 100 mm. Block is O-ringed as well & will displace 3.87 liters.
Darton MID sleeves
OEM Nissan crank ( reportedly good to 1400 hp )
Pauter rods
Arias Extreme Duty pistons ( 9.0 to 1 CR )
ARP studs
JWT S1 cams
Ferrea 1mm oversized valves. OEM heads will have minor port-matching & bowl work.
Ferrea valvetrain ( springs, retainers & locks )
Cometic head gaskets
APS oil pan
IM will either be Crawford ( currently on car ) or Kinetix SSV. John will dyno both & pick the best for my/our application.
Motordyne thermal-barrier lower IM gaskets
350 EVO bored throttle body
3" mandrel bent & thermal coated intake piping
Greddy 660 injectors mounted in John's anodized fuel rails & full return system
Walbro 255lph fuel pump
Aeromotive rising rate FPR
HKS wastegate
Greddy BOV
E-manage Ultimate
AquaMist A-1 water/methanol injection system
Greddy catch can
Gordee's grounding kit
Full Borla exhaust ( headers & TD ) The headers R wrapped in thermal tape.
Labree responated test pipes
DSS axles
Quaife LSD
3.53 geared differential ( might follow Bill's lead & stay w/the 3.3's )
Custom driveshaft ( Maybe 6160 T-6 aluminium or 300M - ask John! )
Level 10 T/C ( 2800 rpm stall ) & V/B. Might be changed to either an SGP beefed tranny or L480E w/paddle shift - we'll see.
ZEX wet nitrous system w/NX Maximizer
J&S Safeguard
SAMCO hoses
Koyo radiator
B&M Hi-Tek tranny cooler
Whew!! I'm sure I've forgotten something but this is probably 90% of the project. Now just don't ask me the total cost!!
MG
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
