SC with dual IC?
Old Mar 9, 2006 | 02:29 PM
ScottGSX's Avatar
SC with dual IC?
Does anyone know if this has been done before or if it's even possible.
I saw a post recently with dual ICs that the connected back to a common pipe.
https://g35driver.com/forums/forced-induction/88958-new-pics-my-new-project.html
Could this setup bee connected to a Vortech or Stillen SC?
Old Mar 9, 2006 | 04:02 PM
luongdmd's Avatar
i think if you have two regular size ic with your sc, the car will take longer to reach optimum temp for performance..... i know that heat is a huge problem for sc, especially with the stillen, but i think the one that comes with the kit is suffice......
Old Mar 9, 2006 | 04:25 PM
ttrank's Avatar
Grocery getter
You can do it but you will be increasing your lag and not gain much from it. Most of the Dual IC setups are for TT. That post is a TT not a S/C, notice there is no blower under the hood, just intake pipe.
The Stillen S/C has heat soaking issues because the Air:Water IC in the plenum is so small. I added water wetter to mine and used the MD Isothermal gasket to try and help a little.
Old Mar 10, 2006 | 01:46 PM
ScottGSX's Avatar
But would dual ICs be better if I am using the stock or Nimos front bumper.
I would think that with a single FMIC the bumper would block a lot of the IC area but using dual ICs might be better.
Any additional thoughts?
Old Mar 10, 2006 | 02:16 PM
roneski's Avatar
Devil's Advocate
I'm pretty sure that the JWT kit for the G35 uses dual intercoolers. The kit for the Z uses a larger single one though. They basically matched it up to the stock open areas of the bumpers.
Old Mar 10, 2006 | 03:29 PM
zazaracing's Avatar
Team Transport Member
your stock bumbper doesnt block all that much air from getting to your FMIC. Yes you can run the dual ic but they would have to be small ones and its more weight and I think youll lose power more than anything.
Old Mar 10, 2006 | 03:55 PM
KjbAlto's Avatar
I have the JWT kit on my G35 coupe and you are right, it uses dual intercoolers that fit up close and right in the openings. It doesn't look like the SFR kit where the intercoolers don't exactly fit in the whole area of the ducts. As far as the Z, they use dual intercoolers on that too but they're connected. It looks like one intercooler but I believe it's two different chambers like the G35 but just connected.
Old Mar 10, 2006 | 06:00 PM
Q45tech's Avatar
Simple to calculate as every 11F is 1% denser charge and every [losted/gained] PSI is +- 6.8% [corrected to STD temperature] denser charge.
Air to Air : Lose 0.5 psi in extra plumbing better drop plenum temperature by [3.4 x11=37F] to be lossless...........
Always have an in plenum temp sensor [fast responding accurate electrical type] to watch what's happening in the system.
Old Mar 10, 2006 | 07:43 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
SFR's TT kit in San Diego came with dual spearco IC's
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
HeyAsianKid
Intake & Exhaust
Oct 7, 2015 01:55 PM
