Can Stillen SC take 05 Vette?
Old Apr 13, 2006 | 02:52 PM
ITmenace's Avatar
Sounds like it will be a good race. Good luck and try to get a vid of it to share with us.
Old Apr 13, 2006 | 03:02 PM
mcy4ever's Avatar
yes yes yes remember to get vids =). I lined up against a vette last night at the track and smoked him i wish it wasnt test tune so i could have gotten a time slip. Im sure your car is putting out enough power to at least be as quick as he is. Good luck im sure it will be a great match up. Im sure that even if you keep up with him he ll be dissappointed in his car.
Old Apr 13, 2006 | 04:24 PM
nate4598's Avatar
yes, will video tape & post it ...only if positive results
Old Apr 13, 2006 | 05:57 PM
klg35's Avatar
1. props for taking it to the track......smartest move by far....
don't forget to volunteer someone from the stand for the vid..
Old Apr 13, 2006 | 06:04 PM
SinCity350Z's Avatar
+1000000
Old Apr 18, 2006 | 12:57 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
the vette will smoke a 298rwhp SC G. Power:weight numbers say that.
Old Apr 18, 2006 | 01:18 PM
nate4598's Avatar
Hope I can fix the issue and bring it up ~350whp
Old Apr 18, 2006 | 06:16 PM
a.k.a. RANDYS_G
Nate, it'd be a first for any Stillen that I know of and even with 350whp, the vettes torque is unmatched unless you go with a TT setup. Good luck.
Old Apr 18, 2006 | 06:36 PM
G35Gnome's Avatar
what kind of launch method did you use and can you describe it...thanks
Break torqueing is the key, when I raced my previus 03 AT G ... I got it up to about 2-2.5k rpm then quickly off the brake and stomp the gas. Now since you have way more power than I had (only exchaust, crawford plenum and z tube) you will definatelly spin the hell out of the tires, unless you have wide aftermarket rubber. I spun the stock 18s every time for like a half second or so with the brake torque technique. Since you have the VB upgrade you can probably go 3-3.5k rpm then. Not sure how good it is to the trans with the VB upgrade, but its not good for stock one, plus it isnt that great on the breaks eather.
Hope you kick his a$$! Good luck.
Old Apr 18, 2006 | 07:04 PM
nate4598's Avatar
Randy,
There's member here getting 343whp with 8psi with DynoJet result...I'm getting over 8.5psi so I hope/wish can get close 350
Old Apr 18, 2006 | 07:07 PM
nate4598's Avatar
Thanks...but I'm currently having problems with my SC...will try to get this fix b4 going to the track
Old Apr 19, 2006 | 11:26 AM
a.k.a. RANDYS_G
Randy,
I don't doubt that...just stating that 350 hasn't been acheived yet. (that I know of)...I wish you the best and will follow your build.
Old Jul 14, 2006 | 05:46 PM
SURFJ9009's Avatar
Results?
Old Jul 14, 2006 | 07:56 PM
G.Ride's Avatar
Originally Posted by SURFJ9009
Results?
must not have been good.
Old Jul 15, 2006 | 04:04 AM
  #30
nate4598's Avatar
sorry...still not have any chance to set this up with him...I'm mostly in NoCal and he's in SoCal
