Just Blew My Stock Motor With APS TT!
Old Jan 7, 2007 | 10:43 AM
  #91
BrianlG35C's Avatar
Ohio G Club Member
I did mean, how is it working out. But it's interesting to know how you did it. Thanks.
Old Jan 7, 2007 | 04:08 PM
  #92
n1cK's Avatar
G35 6MT
Originally Posted by KPierson
Mine still isn't finished (tuned for high boost), and I've been working on it for years. It's rough when you have other higher prioritites in life (wife, house, job, etc). It seems like when I run in to one little problem it turns in to a 3 month ordeal to get everything figured out and fixed. My latest adventure involved dropping fuel pressure at high boost. I just got my fuel pressure regulator replaced, but I haven't even had time to see if it fixed the problem.
i just purchased my first home, so i know how those "other higher priorities" could affect your life significantly. truthfully, i probaby won't start really playing with the engine until i get the damn car payed off in '09. i hope the old mantra "good things come to those who wait" will still ring true then
Old Jan 7, 2007 | 10:59 PM
  #93
G35BASTARD's Avatar
So how much are we talking about when you guys say, "have the block built"? what needs to be added on it for a safer FI add on?
Old Jan 8, 2007 | 06:08 AM
  #94
KPierson's Avatar
I believe a decent set of pistons and rods will run you $3K. While you have the motor out you might as well do cams and have some head work done. You'll also need a complete gasket set. Factor in the labor (assuming you have a shop do it) and you'll be at $7K or so
$3K for internals
$1K for cams
$1.5K for headwork
$1.5K for removal, work, reinstall
You will still need to add your FI device and tuning to this. Don't be surprised if the whole project runs upwards of $20K.
Old Jan 8, 2007 | 08:47 AM
  #95
BrianlG35C's Avatar
Ohio G Club Member
$3K for internals
$1K for cams
$1.5K for headwork
And those prices are low compared to the several quotes I've received. I've been quoted double that for labor when you include reinstalling the turbo kit, then add in gaskets, fluids, supporting cooling mods, upgraded clutch and so on. I've seen pricing anywhere from $10K-$13K, depending on the various upgrades you go with.
Old Jan 8, 2007 | 09:39 AM
  #96
BrianlG35C's Avatar
Ohio G Club Member
Ain't that the truth. That's whats taking me so long.
Old Jan 8, 2007 | 11:39 AM
  #97
G35BASTARD's Avatar
$3K for internals
$1K for cams
$1.5K for headwork
Sounds like it would be better if the block were to just be bought separately and make that the project. This way you can take your time building it, and you wouldn't dig yourself in to a deep hole right away. Just buy/have work done to it as you have cash to spare. Once done, have the motor pulled and switched.
Damn, with all these school loans/bills i'd probably never get done... lol ah well, some day.
Old Jan 8, 2007 | 09:22 PM
  #98
Texasscout's Avatar
http://sgpracing-store.stores.yahoo.net/sgpravqmo.html
Old Jan 9, 2007 | 03:51 AM
  #99
G35BASTARD's Avatar
Ok what? So you buy the built block from them, they charge you the ... lets say Basic $2950 plus the $2200, once you send them YOUR block, they will refund you the $2200?... that doesn't sound like a bad deal, has anyone on here ordered from these guys?
i wonder how reliable are the rebuilt blocks, i know it says 1 or 3 year warranty against "DEFECTS", but what kind of defects? like if were to buy one and boost my car to 400Rwhp and if I were to later look at the sleeves and they had a crack would that be my fault or fall under their defect warranty?
Old Jan 9, 2007 | 01:06 PM
  #100
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
A LOT of ppl have...with positive results...search it.
Old May 14, 2007 | 07:54 PM
  #101
nyqueenz's Avatar
if you gonna build you a built engine u should go with the best stuff.
for my E36 BMW
Forge CP pistiond 8.5.1 CR/ JE if the have them
Forge Pauter rods(spell)
ARP studs
a good steel head gasket.
port a polish head
something simular for the G35 if you wanna max boost.
Old May 14, 2007 | 08:38 PM
  #102
nyqueenz's Avatar
Originally Posted by tony
You cant just lower the boost on the APS kit like that, once tuned that is pretty much what you go with.
change the wasitgate spring to dump at lower boost.
Old May 16, 2007 | 11:08 PM
  #103
cc1012's Avatar
grab an rb25 motor and call it a rap because its a motor thats meant to be turbocharged.
Old May 17, 2007 | 05:54 PM
  #104
G.Ride's Avatar
Originally Posted by Texasscout
Have a look at THESE guys.
to SGP
Old May 17, 2007 | 06:28 PM
  #105
Gman2004's Avatar
Originally Posted by G.Ride
to SGP
although I've never had a problem with the built motor I got from them I had problems with the install of my FCON Vpro and tune done by Mark at SGP.
Read my thread.
http://www.my350z.com/forum/showthread.php?t=268929
