Vortech Owners
Old Apr 26, 2006 | 11:13 AM
sentry65's Avatar
thanks, yeah I have a return system.
actually I messed up my post. Yesterday we were trying to tune and the dyno ran up to 380whp at 6100 rpms. Had we been able to go to redline and had the fuel to, it would have hit 410-415whp - which is around 445-460whp and 360-365 tq on a dynojet.
We were just trying to get some baselines and because we were running out of injector we didn't really do any real tuning. I'm using the 3.12 pulley so there's still lots of room for improvement if I were to upgrade to the 2.87 pulley, but I think the engine is seeing enough stress as is IMO.
Old Apr 29, 2006 | 10:13 AM
Skyline-V35's Avatar
Hi! just installed Vortech S/C on my '03 CPV35 M6 with test pipes & JIC Magic Catback Exhaust... I'm having miss-firing problem event at Idle... I can rev the engine slowly but if a load the gas pedal... it starts miss-firing like hell... plugged the wide band on: Air/fuel is OK, reprogramed the Split Second= ok either!, But still can't the Miss-firing source!!! Any Idea!?!?!? please help!!! anthony-72@hotmail.com
Thanks!
Old Apr 29, 2006 | 12:38 PM
sentry65's Avatar
might try going 1 step colder iridium spark plugs, not sure otherwise
Old Apr 29, 2006 | 02:49 PM
urban's Avatar
It's all in my sig, I have 650cc injectors going in next week along with a Walbro fuel pump. I am also awaiting larger piping for my upgraded FMIC so hopefully with a new tune we should see some new numbers.
Old Apr 29, 2006 | 04:21 PM
sentry65's Avatar
you don't think 650's are too big?
Old Apr 29, 2006 | 07:10 PM
urban's Avatar
I am planning ahead so not really, I am taking the car in later this year to go forged internals and then stick in the T trim SC.
With the Unichip we should be able to get it tuned even with the larger injectors, Ted is pretty darn good with this system.
Old Apr 30, 2006 | 01:10 AM
sentry65's Avatar
nice, looking forward to seeing how it turns out
I figure I'll build my block before going with the T-trim and 650's at this point
Old Apr 30, 2006 | 02:18 AM
urban's Avatar
Does the fuel return system come with an FPR also or is that a separate purchase. I hear that just sticking in the walbro will make my fuel milage drop drastically.
Looks like we have similair mods
Old Apr 30, 2006 | 04:29 AM
zazaracing's Avatar
Team Transport Member
Hey guys I got an ATI but youre right about sticking in that Walbro you MPG take a big ****. If Im lucky on a full tank and normal daily driving I get 220-250 miles per tank. I'm also running 440cc injectors Im sure that has something to do with it.
Just to compare to the vortech setups-
1/2" plenum spacer, Borla exhuast, test pipes, Greddy EU, 7.5psi boost=382hp,322tq. When I dynoed I have a huge exhuast leak so I know my tq has gone up a lot since then maybe at like 350 now. Also Im running rich to be on the safe side.
Old Apr 30, 2006 | 04:46 AM
sentry65's Avatar
FPR comes with fuel return kit
Old Apr 30, 2006 | 04:36 PM
I changed the plug with NGK Iridium one step colder plugs... still having the miss-firing issue... Anyone knows if the FMU on the vortech S/C kit might causing the problem even at idle & even if the A/F ratio is ok?!?!?!?
Old Apr 30, 2006 | 04:43 PM
booger's Avatar
No....The FMU doesnt even turn on till your into boost or the rpms are around 3000 . Have you looked into a bad coil ?
Old Apr 30, 2006 | 07:22 PM
Dan_K's Avatar
How much more of a risk is there to run the 3.12 pulley? Assuming everything else is stock.
Old Apr 30, 2006 | 07:51 PM
sentry65's Avatar
not a lot, but you might end up needing to upgrade the fuel injectors possibly to 440's
Old Apr 30, 2006 | 10:05 PM
  #30
urban's Avatar
Sentry, first you need to take a break from the board as you are always on and second as you are in the process of building your car up you must have hook ups and the CJM (spelling) return fuel system for a good price, so help a brother out and get me a discount or if you know of someone who is selling one
