Vortech: pulley bearing noise!?
Old Sep 1, 2007 | 09:44 PM
waijai's Avatar
i.love.gold
Got the Dayco 89009 which is indeed the correct pulley. Replaced them today and all my squeaks are gone.
Dayco 89003 for the smooth idler pulley
Dayco 89009 for the ribbed idler pulley
Old Sep 2, 2007 | 12:21 PM
BeerViper's Avatar
Sorry Moog, I had posted the part numbers over on my350z.com and not here... http://my350z.com/forum/showthread.php?t=187844
Glad you got it figured out though!
Old Sep 2, 2007 | 05:07 PM
waijai's Avatar
i.love.gold
not exactly the same part #, but I found one that works
Old Sep 2, 2007 | 05:33 PM
TwilightBLUES's Avatar
yea mine makes a sqeaking noise, it seems more often when its colder. It kinda of sounds like the belt but its not. i changed all the idler pullies but the noise was still there. maybe the jacknife is the issue? anyone with this same problem?
Old Sep 3, 2007 | 03:23 PM
Hexxum001's Avatar
I have a little bit of squeaking but just at startup sometimes. I'm pretty sure it's just my belt and it just needs to be tightened a bit.
Old Sep 13, 2007 | 01:04 AM
Mr_pharmD's Avatar
which pulleys are u guys reffering too? I'm having a similar noise. Are u reffering to the cog pulleys near the top? If so, where can I get them???
Old Sep 13, 2007 | 02:46 AM
imalazeeass's Avatar
all these noises with the vortech!!
Old Sep 13, 2007 | 03:15 AM
Triji's Avatar
Mine is now quite since I did the GTM idler pulley MoD
Old Sep 13, 2007 | 08:12 AM
waijai's Avatar
i.love.gold
We're referring to the 3 idler pullies on the left hand side of the mounting bracket. One smooth and two grooved.
Old Sep 13, 2007 | 08:55 AM
BeerViper's Avatar
Mine ended up being 1 of the 2 bearings inside the cog assembly that are pressed in. One of the bearings was shot.
Old Sep 18, 2007 | 12:59 AM
Hexxum001's Avatar
Tell me about it. My car went back to GTM today. Saturday it started making this horrible noise. Not the squealing noise of a belt that is loose. A lot worse. I couldn't really tell if it was coming from the SC or the bearings. I decided not to take any chances either way. Damn, sux to be having this problem after having the Vortech less than 3 months.
Old Sep 18, 2007 | 02:43 AM
serious? so soon? let me know what Sam says about it.
Old Sep 18, 2007 | 11:30 AM
Hexxum001's Avatar
That's what I'm saying. So soon?? Either way, if it's an issue with the SC, it's under warranty. It sounded really bad though. Dru (Meechin) came over to my pad and listened to it. He said it almost sounded like a metal on metal kind of noise. Hopefully it's something minor that can be fixed quickly. I compared it to the bearing noises that have been posted and it doesn't really sound like them so we will see.
Old Sep 18, 2007 | 12:33 PM
BeerViper's Avatar
It could just be a pulley bearing. These bearings are just your run of the mill bearings and could be defective from the factory or have a bad seal where the grease leaks out.
If it's one of the pulley bearings on the mounting plate, that is like a $10 fix. If it's the bearings in the jackshaft (like mine) then it involves a little more work to get the bearings out of the jackshaft assembly. If it's bearings in the blower assembly it will have to go back to Vortech.
Good luck.
Old Sep 18, 2007 | 01:01 PM
  #30
Hexxum001's Avatar
Thanks. I still don't have enough experience with the Vortech to know the difference. That's why I sent the car back to GTM. Hopefully it's just the bearing. I don't want to have to wait a few weeks if it's the blower.
