Future Models Questions, requests, info on Future Infiniti/Nissan Models
The rumors are strong, 2009 G37 sedan 330hp
Old Dec 16, 2007 | 02:19 AM
gt_performah's Avatar
Originally Posted by tagheuer
They better up the power and decrease the weight, they are getting SMOKED by the 335.
I think SMOKED is an exxageration.
I think you guys are off your rocker if you think Infiniti engineers is sitting around worrying about the .6 second advantage the 3 series has over the G. Infiniti will continue to offer the best all around vehicle at a competitive price and the 4,000+ sales a month means they are doing a good job. That does not involve winning 0-60second battles.
A G37 sedan should be faster than the G35 sedan but there is no guarantee it will end up being faster than 3 series. Weight is still a factor and the 3.7 is heavier.
Old Dec 16, 2007 | 02:40 AM
DaveB's Avatar
Seeing that the G35 sedan weighs in at 3,600lb and the G37 coupe at a boggling 3,800lbs, it's no wonder the G35 sedan posts equal or better times than the more powerful G37 coupe. Throw the VQ37 into the sedan and it's going to flat out smoke the G37 coupe. The VQ37HR hardly weighs anymore than the VQ35HR. You're talking 200cc's of extra displacement. I think the weight difference between the two is like 5lb or 6lbs. Why would Infiniti intentionally add weight to the sedan if they didn't need to? If the VQ37 makes it into the sedan, I'm getting one....eventually
The G35 sedans are currently posting 13.8-13.9@102mph on street tires. There's no doubt in my mind a G37 sedan will do 13.5-13.6s@104mph on street tires and 13.2-13.3 on DRs. That's more than competitive with stock 335i's. Now if the 335 adds a chip, then all bets are off.
Old Dec 16, 2007 | 09:02 PM
chilibowl's Avatar
+1 , end of thread. Unless the 37 coupe gets more power from its 3.7L VQ37VHR, atleast 345-350....then im getting an 09 G37 Sedan. Weight will never be lowered so thats out the window. The only way to make that pig faster, is to add more power, and keep weight at where it is.
Old Dec 16, 2007 | 09:04 PM
speedracerg35's Avatar
Originally Posted by logik05se
Maybe your 35 is the last gen. But the 3.5HR is by no means .5 second the g37 in any anything.
is this english?
Old Dec 16, 2007 | 09:08 PM
Originally Posted by chilibowl
Highly doubt thats going to happen. Do you think an increase of 24 HP is worth the differentiation of cars? Nope. Its going to be a G37, or nothing.
why wouldn't it? nissan does it with every car they have. infiniti does it with the m, and fx series.
edit sentr 2.0/2.5
altima 2.5/3.5
maxima 2.5/3.5
m35/m45
fx35/fx45
Old Dec 16, 2007 | 09:12 PM
Originally Posted by AlterZgo
There's no doubt 30 addt'l hp would improve performance. However, if you read my post, I indicated there would likely be a corresponding increase in weight as virtually always happens when cars progress in their model cycle.
I then said a heavier G37 sedan would likely have minimal improvement in performance. This is evident in the fact that the heavier G37 coupe has virtually identical acceleration to the 07+ G35 sedan.
At this point, there is no objective test that indicates a G37 sedan would be .5 sec quicker from 0-60 and in the 1/4 mile than a G35 sedan. In fact, it's highly unlikely a G37 sedan would go from a 13.8-14.1 sec 1/4 mile car to a 13.3-13.6 sec 1/4 mile car with only 30 extra horses even if the weight was kept exactly the same.
If you're comparing your 1st gen G35 to the G37, there's more than a 30 hp difference in power because the G37's 330 hp rating is based on the more conservative SAE net rev 8/04 rating whereas the G35 coupe's 298 hp is based on the old rating method. Thus, the actual difference in power between your G35 and the G37 is likely over 40+ hp. That, and the fact that the VQHR motor has been heavily revised with a wider powerband and higher redline is why the G37 is a good 1/2 sec quicker 0-60 and in the 1/4 mile than your car.
I'm curious to know what I've stated that you feel is inaccurate or would indicate I don't know what I'm talking about.
first, what makes you think a sedan with a 3.7 would be heavier? the extra weight in the coupe comes from the redesign...engine doesn't weigh 300 extra pounds.
second, try being more clear in you logic and writing. you state that a difference in weight coupled with an increase in horsepower would show no increase in performance. why would anyone think you were comparing a 37 coupe and a 35 sedan, and then comparing that to a possible 37 sedan (with what you are sure will weigh 300 pounds more). when you talk about corresponding weight and power increase, as you stated in your reply, you should be comparing apples to apples. a 37 coupe and 35 coupe (which would be the logical comparison) there is a significant increase in performance.
edit: hence, since the coupe weighs an extra 300 pounds and shaves of half a second in 0-60 and 3 to 4 tenths in the quarter miles, it would be easy to assume that a 3.7 in and existing platform with thirty or so extra horses would have a dramatic increase in performance.
Old Dec 16, 2007 | 09:29 PM
chilibowl's Avatar
lol , youre talking about added cylinders here homie, not +25 HP.
M35 = V6
M45 = V8
Old Dec 16, 2007 | 09:33 PM
M35 = V6
M45 = V8
you may be correct, you may not. there are plenty of other manufacurers (including bmw) that offer different displacements in the same model with the same cylinder count.
Old Dec 16, 2007 | 10:18 PM
N50's Avatar
N50
I'd love to see the 3.7 liter in the sedan. I'll believe it when I see it, though.
Old Dec 17, 2007 | 02:37 AM
jackygor's Avatar
infiniti should be closing in the performance gap between the g35 sedan and 335i sedan if the rumors are true.
Cheaper as well? Not sure how the market will respond to thaet.
Old Dec 17, 2007 | 03:52 AM
dec55's Avatar
For the Sedan to really compete, it should get down to 0 to 60 in 4.2 secs.....:lol
This alone would drive the competition nuts.
Come on....trickle down GTR technology.....Infiniti is waiting...
Old Dec 17, 2007 | 08:59 AM
opus's Avatar
Does anyone think there will be a V8 G45 or G50 sedan?
Old Dec 17, 2007 | 09:03 AM
chilibowl's Avatar
I dont think that will ever happen, thats what the M is for. Theres no need for a V8 in the G line, the V6 is powerful enough.
Old Dec 17, 2007 | 11:14 AM
DaveB's Avatar
Only if they want to go after the IS-F which I highly doubt they care about. In order to squeeze the V8 in there, they'll need to raise the hood, rework the fenders, and push the nose out a bit like Lexus did for the IS-F. Seeing that Infiniti doesn't have a competitve V8 to the IS-F V8, there's really no point. It would make more sense just to drop in a detuned VR38TT.
Old Dec 17, 2007 | 11:23 AM
  #30
fecurtis's Avatar
Originally Posted by theimmortal
...Aluminum hood, roof and trunk, maybe some carbon fibre & kevlar driveshafts, carbon fibre shell sport seats with aluminum sub structure both front and back. Lighten it up where possible without increasing cost (significantly or at all if possible).
Cut out the luxury items such as NAV, cameras, and anything else not driving related, but leave the comfort and convenience items (who wants manual windows, no stereo and no a/c?).
Reduce the Noise, Vibration and Harshness and make that motor buttery smooth (counterbalance???) so that the magazine reviews have nothing to complain about.
...just a few thoughts.
Worst idea ever. Hows it supposed to be a luxury sport sedan without those items?
