The FX-Spot For General discussion of the FX35/FX45
Thinking Of Buying An FX, Couple Questions
Old Nov 19, 2007 | 10:47 AM
Destro's Avatar
I am looking at trading in my 05' G35 coupe on an 06' FX35. I was wondering if any of the parts from the G will fit on the FX? I have a Fast Intentions exhaust, Motordyne plenum and spacer, and JWT popcharger and Z-tube.
I tried to search but couldn't find much info, other than that I don't think the Z-tube will fit.
Old Nov 19, 2007 | 12:19 PM
2drwild's Avatar
go to infinitifx.org.
Old Nov 19, 2007 | 12:24 PM
da mayor's Avatar
yes you can use your FI exhaust on the FX w/ small modification to the tips to extend them out.
plenum spacer will work along w/ the popcharger and z-tube.
i had an injen from a coupe fit in there w/ small modification -- had to add an extra bushing by the engine bolt so it sat at the right height.
Old Nov 19, 2007 | 12:33 PM
Destro's Avatar
So, just the tips would need to be extended a little? I figured the plenum and spacer would fit fine.
Old Nov 19, 2007 | 12:35 PM
da mayor's Avatar
some exhaust tips will have to be extended depending on what type of exhaust u have. im not exactly sure with each specific exhaust
Old Nov 19, 2007 | 12:50 PM
Destro's Avatar
Thanks, maybe I will e-mail Fast Intentions and see if they know. Either that or I will just sell it.
Old Nov 19, 2007 | 12:55 PM
C_Lawd's Avatar
I just traded my G for an FX. I loved my G, but this FX is just badazz!!!
Old Nov 19, 2007 | 12:57 PM
rookie's Avatar
The FX and the G coupe wheel bases are the same. The difference to fit the exhaust will be how long the tips are. Are you getting a RWD or AWD? I don't recall the front pipe design of the Fast Intentions but some exhausts will have issues with transfer case clearance.
Old Nov 19, 2007 | 01:09 PM
Destro's Avatar
AWD, fully loaded. I called FI and they said that some of their customers have said it will fit, but they have not actually tried it.
Old Nov 19, 2007 | 01:11 PM
Destro's Avatar
I drove it last week and fell in love with it. Plus it has so many features my G doesn't. I have a 2005 fully loaded coupe, but the stereo display sucks, no bluetooth, no rearview camera, no I-key. The FX is a 2006 and has the nice stereo display that is in the NAV screen, and has all those other features.
Old Nov 19, 2007 | 01:14 PM
C_Lawd's Avatar
Sounds like mine. 2006, AWD, Sport pkg, Tech pkg (LOADED)
Old Nov 19, 2007 | 01:42 PM
Destro's Avatar
Only thing it doesn't have is the flip down roof mounted dvd player. I don't plan on having kids so I really don't care about that.
Old Nov 22, 2007 | 09:47 PM
brownfv's Avatar
Everything should fit just fine! only thing you might have a problem with is the FI exhaust, because it is true dual, im not sure if the H-pipe will clear the AWD housing....
Old Nov 23, 2007 | 07:57 AM
Destro's Avatar
I got everything off the G except the plenum and spacer (didn't have the old bolts or the time to do it). I will have to test fit the exhaust. If it won't clear it then I will have to sell it.
Old Nov 25, 2007 | 06:59 PM
iknowitsfast's Avatar
i just went from a 350z to an FX last Tuesday. Man was I upset, but after driving this FX all week im pretty happy, All the pros outweight the cons, and my popcharger fits perfectly since its the same engine. You shouldnt have an issue at all.
