07 fx35 front brake rotors?
Old Feb 17, 2009 | 08:28 PM
Bluebeast's Avatar
The front rotors on this car have warped twice, does anyone know where to get replacement rotors that are not slotted and will hold up. I used the brembo replacements before on other cars but I cant find them for the fx. Thanks for any help!
Old Mar 14, 2009 | 04:05 PM
Solekeeper's Avatar
Go OEM. Btw, there is no such thing as warped rotors. And if their that bad anyway, they should have been replaced, stop resurfacing them.
Old Mar 18, 2009 | 02:30 AM
bythabay's Avatar
I'm not sure if they make them for the fx, but I've had good results with r1concepts rotors on many g35 cars
Old Mar 21, 2009 | 11:23 AM
Bluebeast's Avatar
Did that guy say no such thing as warped rotors? aaaaanyyyyway.... I got the r1 concepts and they are great and pretty inexpensive too Thanks!
Old Mar 21, 2009 | 01:56 PM
Solekeeper's Avatar
Like I said go OEM, stop being a hard ***.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
I have re-surfaced my rotors once, I won't do it again.. I say once is the most you want to re-surface a rotor. Each time (You are making it thinner and thinner)
Old Mar 28, 2009 | 07:47 PM
Bluebeast's Avatar
I read that article, I still believe and have read articles online about heat warping rotors, as well as other things like blackspotting, and torquing the lugs correctly... But you win.. anyway, I have never resurfaced the rotors on this car and my new ones are doing the same thing as the last. The reason I do not want to go oem is because on my previous g35 my brakes were always pulsating as well even when replaced...
Old May 30, 2009 | 03:27 PM
pwebb's Avatar
put well used rotor on a brake lathe, and try telling me theres no such thing as a warped rotor.
it will dance all over the place.
Old Sep 28, 2009 | 01:34 AM
Bluebeast's Avatar
i agree i am now going through the same thing with fx 45 rotors on my girls car, are these the same rotors as the fx35?
Old Feb 2, 2010 | 03:47 PM
jumbosrule's Avatar
The OEM FX rotors can wear a total of 2mm (both front and back). Proper procedure is to check the rotor run-out while still on the car.
http://www.ebcbrakes.com/automotive/...r_runout.shtml
If runout is inside specification, no change. Outside spec, they can be turned down as often as needed, till they reach the minimum thickness. Then it's time to replace. I had my OEM rotors turned down three times before having to replace them at 65,000 miles.
I now have the Stoptech rear replacement rotors (stock size) and the Stoptech BBK. Both of these can be turned down if needed - both are cross drilled.
jsimonk
Dec 22, 2023 03:49 PM
Terry_G35
May 9, 2020 01:39 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
Terry_G35
Aug 4, 2015 02:38 PM
wojowojo16
Jul 27, 2015 09:57 AM
