G35 & G37, Coupes & Sedans
New Grounding Point! What do u think Gordgee?
Old Jun 3, 2006 | 08:35 PM
aleok's Avatar
look what i found! right in the middle there.
thinking about adding another wire to there.
what do u think?
Old Jun 3, 2006 | 08:52 PM
truplay8's Avatar
THE BATMOBILE
interesting........anyone know anything about this??
Old Jun 3, 2006 | 10:09 PM
Mr.GEE's Avatar
20 Year Member
That is the knock sensor. It is a donut shaped device with an electrical connection along the circumference and a metalic base that contacts the engine. The bolt going thru the center, holds it tight against the mounting surface. I don't think there is an electrical grounding connection, it picks up the shock from engine detonation and sends signal to the control module.
Old Jun 4, 2006 | 01:00 AM
aleok's Avatar
so whats it for? can i put a grounding wire on there too? lol
Old Jun 4, 2006 | 01:04 AM
EricIsKlumzyee's Avatar
no you dont need one.. if you hook a volt meter up to it and shake it you'll see that it produces voltage..
the only ground GG is missing is the ground thats below the intake variable valve sprocket.. those of you thats installed the stillen engine damper know what i'm talking about
Old Jun 4, 2006 | 01:23 AM
speedgeek's Avatar
There's also a nice healthy ground below the washer reservoir. If you look there are two nice bolts holding that baby down. I'm also tied into that grounding point.
Old Jun 4, 2006 | 01:57 AM
MechEE's Avatar
Just say no to adding ground loops.
Old Jun 4, 2006 | 02:14 AM
trackmagic's Avatar
Say no to *****
Old Jun 4, 2006 | 09:56 AM
RBull's Avatar
Rated M
You've made your point many times. I respect your point of view but it becomes tiresome to read the same thing so often.
Old Jun 4, 2006 | 02:39 PM
rupdog326's Avatar
Out of many - one people
He must have an alert set up to notify him everytime someone post something about automotive grounding. He is like an attack dog to the grounding market.
Old Jun 4, 2006 | 03:07 PM
RBull's Avatar
Rated M
Could be. He's certainly on the ball with it.
Old Jun 4, 2006 | 09:10 PM
Andy2434's Avatar
Shhhhhhhh . . . He's coming back. . . beep . . . . . . . . beep . . . . . . beep . . . .beep . . .beep . . .beep . .beep . .beep .beep BEEEEEEEEEEEEEP! He means well.
Old Jun 4, 2006 | 09:13 PM
TURBOTOM's Avatar
a.k.a kleicoupe
LOL
Old Jun 4, 2006 | 11:20 PM
aleok's Avatar
anyway do you see anyother ground points, since i have everything off?
Old Jun 6, 2006 | 04:50 PM
MechEE's Avatar
The notion of adding secondary ground loops is very different from the idea that swapping your stock ground wires for larger aftermarket wires increases performance. One can drop the characteristic impedance of the ground pathways WITHOUT adding additional loops. You should at least fully comprehend what I say before you're justified being anti.
